05-11-2015, 08:29 AM | #1 |
Advansolosis
218
Rep 1,448
HELP: CODES!
After the lovely mother's day dinner, I started up the car and it felt like the car choked for a bit, the RPM jumped down to 500rpm and popped back up.
I went home, checked the codes and have the following.... Torque 1 Missing message (PT-CAN 00D354) Torque 2 Missing message (PT-CAN 00D355) Torque 3 Missing message (PT-CAN 00D356) CAN Message 00E717 CAN Message 00E71A CAN Message 00E71B CAN Message 00E720 I have a Dinan Tune and DCT GTS software any clue?
2011 E90 M3, ESS VT2-650, 2015 GL550 |
05-12-2015, 02:16 PM | #3 |
Bad Lieutenant
233
Rep 3,517
Maybe the low fuel pressure sensor. Have you searched here for similar codes?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
05-12-2015, 05:55 PM | #6 | ||
Advansolosis
218
Rep 1,448
I'll do that! Thanks guys!
05-13-2015, 09:56 AM | #7 |
Bad Lieutenant
233
Rep 3,517
I believe you can get a visual on the ambient sensor in the driver's side brake duct. Check and see if it's still intact. Objects can fly in there and snap it as it's just cheap ass plastic.
05-13-2015, 12:15 PM | #8 |
Advansolosis
218
Rep 1,448
It seems like it is still in tact. not sure if the wiring behind had came loose. Going to replace it this weekend anyways just incase.
05-13-2015, 05:33 PM | #10 |
Advansolosis
218
Rep 1,448
Thanks, I did clear the codes, cranked the car up and the codes went away. I didn't drive it tho, I just let it ran for another 20 mins. However, the ambient temp sensor was still over 100deg.
05-13-2015, 05:36 PM | #11 | |
Rep 538
It was the DME module which had those codes posted against it? |
