BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      04-20-2015, 11:30 AM   #1
bachma
bachma's Avatar
Drives: 2009 Space Gray M3 e93
Steering wheel vibration
I just got my 60K miles maintenance service done. There was some cupping on my front tires so they did an alignment. I was getting some steering wheel vibration before the service, so I thought the alignment might help. Still getting it though at around 80 mph. Could the uneven wear of the front tires be contributing to the vibration, or could it be something else?
CURRENT RIDES: 2009 Space Gray E93 M3; 2008 Jet Black X5 3.0si
PREVIOUS RIDES 2009 Jet Black 135i; 2010 Space Gray 335i Coupe; 2008 Jet Black 335i Coupe; 2006 Carbon Black M3 ZCP (R.I.P 10/27/2007)
      04-20-2015, 12:29 PM   #2
kwality
Drives: E92 aw m
your tires may be out of balance and or spacers are the cause.
      04-20-2015, 12:55 PM   #3
Groundpilot
Groundpilot's Avatar
Drives: 135I DCT , e92 M3 DCT, Audi A6
I would check the flat spots or any debries on the tires and rebalance all wheels. If that doesnt fix it, then check if any wheels are bent, then look at the front suspension. In that order
      04-20-2015, 01:38 PM   #4
bachma
bachma's Avatar
Thanks. It probably is a balance issue. One of my front wheels got bent a couple of months ago, but the wheel was fixed and balanced fine at that time. I'll balance all the wheels and see the results. If that doesn't help, then I'll take a look at the suspension.
m3post
