Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      04-11-2015, 10:16 PM   #1
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
Drives: m3 zcp, macan GTS, f15 x5
Issues with m4
Hi all,
I LOVE My new my m4.. had a couple of issues I wanted to inquire about prior to taking it to the dealer
1. hoodclosing- I Noticed that the hood isn't closing easily. I feel if I close the hood and try to push it closed it will not, I have to almost slam it shut or it won't close. Sometimes I have to lock and unlock the car for it to work even when slamming... any insights?
2. seat belt light- 3 times during driving I have gotten the seat belt warning and chime... coincidentally I have had my cell phone on the passenger seat during these time.. has anyone else had these issues??
thanks
jawwad
2017 991.2s
2015 F15 35i
2017 Macan gts
      04-11-2015, 10:31 PM   #2
Woodengun
Drives: Yugo
I drop my hood to close it. Ka-klunk. Or i have to press down on latch points...prefer kaklunk.
The seat is sensitive but a phone? I know my ~10 pounds of computer and work papers makes the seat think there is a passenger.
      04-12-2015, 03:04 PM   #3
Vigilant
Vigilant's Avatar
Drives: Cautiously fast
Drop the hood to close. The BMW genius at the PCD showed me how to press on the latch points, but I am concerned that I will bend/depress the aluminum hood.
2022 BSM G80 Comp X-drive
      04-12-2015, 03:14 PM   #4
allenjanthony
Drives: BMW M4 F82
I've had the same experience with the seat belt warning and chime. Mine occurred with a cell phone in the passengers seat as well.
      04-12-2015, 04:19 PM   #5
Hawaii i8
Hawaii i8's Avatar
Drives: 2017 i8 coupe
All standard stuff.. Drop the hood to close (Check the catches on both sides have locked into place) - I can't even put my MacBook air on the seat beside me, the Airbag sensor is very sensitive, so I just put in in the back seat now :-(
"AY Brave!"
      04-12-2015, 05:42 PM   #6
Vectors2final
Vectors2final's Avatar
Drives: 2018 F80 YMB/SS ZCP
The phone thing happened to me in my Volkswagen(s) and my Mustang(s)... this isn't a BMW specific thing.
You can also adjust the rubber on the hood to allow for easier closing.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M
Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M
      04-12-2015, 06:00 PM   #7
Who's on first
Who's on first's Avatar
Drives: A-10C
Seatbelt also, as well as a few random frontal collision warning red car on HUD and dash.
Side note--- I HATE how you have to slam the trunk to close it completely.
      04-12-2015, 10:01 PM   #8
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
ok so all this stuff is normal it seems.
2017 991.2s
2015 F15 35i
2017 Macan gts
      04-14-2015, 10:31 AM   #9
Woodengun
Drives: Yugo
For the trunk, there are 2 plastic stops you can adjust to make closing the trunk a bit less forceful. Look on the edge of the trunk lid, a bit wider than shoulder width from the lock mechanism. You will find a plastic stop knob that can be screwed in/out to adjust how much force is needed to close the trunk.
      04-15-2015, 07:02 AM   #10
Who's on first
Drives: A-10C
I will try this.
Thanks.
      04-16-2015, 10:01 PM   #11
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
They made the hood "tighter" on F8x and later F3x because on the earlier F30's the hood was "easier" to close but then ran into problems of them not "springing" up enough to where. You could make the 2nd pull to fully release it.
On my 2012 F30 eventually after pulling the 1st time I would have to go and pull up on the hood by hand and then go back into the car and pull the handle again then I could open it.
To close your hood just drop from about 15-20" above and it will fully close with no pressing down.
      04-17-2015, 07:39 AM   #12
BPe90M3
BPe90M3's Avatar
Drives: 2011.75 AW e92 M3
Originally Posted by jawwadh View Post
Hi all,
thanks
jawwad
HAHA I have the same quirks!! The hood takes so force, or dropping it a little higher. The seatbelt chime really gets to me. How does my 400 gram cell phone set off the seatbelt chime?
      04-17-2015, 10:24 AM   #13
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
must be a mineral white M4 problem
2017 991.2s
2015 F15 35i
2017 Macan gts
f80post
