03-21-2015, 05:00 PM | #1 |
Rep 21
Oil pan bolt
So I went to change my oil today and when I went to remove the bolt it just kept turning. The bolt itself is not stripped but it just keeps spinning and does not loosen or tighten. Any ideas?
03-21-2015, 06:12 PM | #3 |
Rep 4,429
It happened to me. Turned out that my oil pan threads were stripped. My Indy shop did manage to get the bolt out and was able to retap the threads. Way more cheaper than replacing the oil pan!
http://www.m3post.com/forums/showthread.php?t=1037741
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
03-21-2015, 06:41 PM | #4 |
Rep 24,671
Fortunately you have not lost the drain bolt !
And while driving ....Guess what could happen
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
03-26-2015, 02:46 PM | #5 |
Rep 947
Not a big deal. Get the pan remove the 1,000 bolts around the perimeter of the pan. Get the drain bolt out by applying some force on the inside of the pan and at the same time trying to unscrew the bolt. With luck it should be out in no time. Get a repair kit and fix the thread. If it's too bad or if you don't want to go this way then get a used or new pan.
