03-16-2015, 09:28 AM | #1 |
Rep 67
Drives: E93 M3 Melbourne Red
This vehicle part is plastic which logically can be fixed with melted plastic. Hence, the glue gun. It is not as rigid as the original material but it'll do.
Materials: 1) Glue gun (preferably w/ high-low settings; Stanley brand @ Home Depot) 2) Flex Seal spray -black (Home Depot) 3) Tools to remove side splash guards ( box wrench & socket wrench: 10 mm?) Steps: 1) Remove the side splash guards from under front bumper. There is a total of 5 bolts. 3 in the wheel well, 1 under the bumper & 1 right behind the under the bumper bolt. 2) wipe clean all areas 3) Line up all broken parts & save as much pieces as you can 3) Lay splash guard on cardboard or aluminum foil 4) Stick everything together with glue gun & any gaps can be filled in by glue gun. 5) Spray external surface of part with Flex Seal. Let dry overnight. 6) Install Waiver: I'm not responsible for any injuries, dismemberment or death that might result from this DIY. |
03-17-2015, 02:40 PM | #2 |
Rep 49
Thank you! I am doing to do this over the weekend. I was going to purchase a new right side cover but for the $20 or so bucks it would cost to fix it, this makes more sense.
03-19-2015, 06:24 AM | #3 |
Rep 10,614
I patched mine together with some salvaged plastic and a pop riveter. I like the flex seal idea to improve the appearance since a little is visible from the front of the car. My car is slightly lowered and I scrape this part. I don't want to spend $200 every 2 years on new parts that I will also break.
03-19-2015, 07:36 AM | #4 |
Rep 67
Always glad to be of help!
