02-27-2015, 09:49 PM | #1 |
Rep 40
Recommended maintenance
Good evening everyone, I just grabbed a 2009 e90 m3 with just 7k miles, the car even smells like new I couldn't be happier. The previous owner kept it in the garage for the past couple years with almost no use. My question is even though it has low mileage what parts would you think I must check out for manteinance not for mileage but for time?
02-27-2015, 09:59 PM | #2 |
Rep 1,479
Drives: 2017 F80 M3
Did you get the service history? Engine oil and brake fluid should be changed at a minimum on a yearly basis.
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
02-27-2015, 10:10 PM | #3 | |
Rep 40
02-28-2015, 02:08 AM | #4 |
Rep 7,130
Congratulations and welcome OP!
7k miles on a 2009, now that is special. Tell us a bit more about the car man, and don't forget pictures! Cheers |
02-28-2015, 06:41 AM | #5 |
Rep 620
02-28-2015, 07:41 AM | #6 |
Rep 7,130
02-28-2015, 09:16 AM | #7 | |
Rep 1,044
I'm at 9888 (garaged for the winter). According to the service history, last service was done at 7500. I think what I'm going to do is have the oil changed/serviced at the dealer as soon as it comes out of the garage. Then, every OTHER oil change will be done at home. Probably every 3500...just to be safe.
I did a lot of things to it. |
02-28-2015, 10:18 AM | #8 | |
Rep 966
02-28-2015, 10:40 AM | #9 |
Rep 1,044
I feel like a lot of the rod bearing failure comes from this whole new idea of stretched duration between oil changes. I know it CAN go at least 7k. But, do I want it to? Heellllll to the no!
MAYBE 5k. But, that's where I draw the line...haha.
02-28-2015, 10:52 AM | #10 |
Rep 11,891
It's unbelievable someone bought a $70k M3 and basically didn't drive it...
I would change the oil and brake fluids. Also the brake pas themselves are probably up for replacement, but you have to check the CBS. You should also check the battery. May I ask how much you paid for this car? |
02-28-2015, 10:59 AM | #11 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
Congrats OP on your Basically New M3! Enjoy it, it's a car that begs to be driven!
I'm not going to repeat the good advice you already received, BMW's when not driven enough have a habit of their original battery depleting. You will first notice this by the clock starting to lose time. I have 2 battery tenders and switch them out with my BMW's. Without a tender and driven infrequently you can expect the battery to have a life expectancy of approx. 3 years. Enjoy! Chris
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
02-28-2015, 11:49 AM | #12 |
Rep 1,044
I don't see this as a bad thing. I only plan on driving mine when the sun is shining, the road is dry, and the windows can be rolled down. In my area of the country...that's about 5 months out of the year
02-28-2015, 11:54 AM | #13 |
Rep 11,891
well i think people's perspectives on car usage is different. I'm also a low-mileage M3, but at one point, it's just doesn't make sense financially to buy a car and not drive it. It's one thing if it drop 8k a year, but 8k in 6-years for a new car is almost unheard of outside of exotics...
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
02-28-2015, 04:13 PM | #14 |
Rep 620
You can do whatever makes you feel good, but I have done Blackstone Analysis on every oil change I have done ranging between 4k and 9k miles and nothing I have seen on the reports makes me think the oil needs to be changed more regularly... I change mine annually because I have yet to put 10k miles on it in 1 year...
02-28-2015, 10:39 PM | #15 |
Rep 468
Don't forget about the coolant, and maybe the power steering fluid. Also check the microfilters to make sure they are molded badly or anything.
And...wow...7k miles. Well done. Enjoy! As for oil intervals...if you are paranoid (which is not a bad thing) then I suggest you start with 7.5k interval and get regular oil analysis reports. Let the DATA drive any interval less than 15k...not anecdotes. |
03-02-2015, 09:57 AM | #17 |
Rep 40
Thanks for the heads up everyone! I paid $31,250.00 which is under the market I assume. I don't plan to daily drive it either, i'm posting some pictures tomorrow for sure. BTW it is losing time repeatedly and one time I was listening music with the engine off and the battery warning poped up I assume the battery needs to be changed too. I already changed the engine oil, air filter, brake fluid and cabin micro filter. Do you think steering fluid is a must too?
03-02-2015, 10:15 AM | #18 |
Rep 1,197
Drives: 2021 F87 M2c. LBB, 6mt
WOW, that is a crazy deal! Awesome buy!!
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
03-02-2015, 10:17 AM | #19 |
Rep 3,633
Totally wrong. If you want, change it every 7500, otherwise it's throwing money away.
03-02-2015, 01:28 PM | #21 |
Rep 661
03-02-2015, 01:43 PM | #22 |
Rep 214
Drives: 2012 E92 M3 ZCP 6MT AW/BLK
I have been doing 5k mile oil intervals on my M3 for almost 2 years now. I daily drive it in all the weather, some days below 0 and I drive many miles a year. ALWAYS start it a couple minutes early and ALWAYS let the oil warm up before getting anywhere close to even 3k rpm. The cost of the extra oil changes is minor to me. Love this car!
2012 BMW M3 ZCP 6MT |
