BMW X5 and X6 Forum 2014-Current
      01-11-2015, 10:23 PM   #1
LatinBimmer
Peru
135
Drives: X5 2014 Sparkling Brown
NBT Retrofit F15 [Full Guide]
Retrofit NBT in F15
Hello buddies, for all of you who bought the F15 with standard 6.5” CIC display, you can successfully retrofit NBT with 10.2” full HD display. First of all, my deeply gratitude to opasha and shawnsheridan , 'cause without their amazing help, this wouldn't be possible at all.
Ok, first things first, what do you need?
•Complete NBT system (used it’s ok). The complete set comes with:
-10.2” Display
-Head Unit
-iDrive Touch Controller
•Video Cable (part # 61119261850). Believe me, your current CIC video cable looks the same, but it’s not and won’t work)
•NBT adapter (in order to use Navigation, Voice Control and Apps)otherwise, everything else Works perfect.
•Coding.- (special thanks to Shawn and Omar for their help and hours of work and patience)
Here are some pics of what you need:
NBT
Video Cable
NBT Adapter
Ok, let's do this:
Step 1.- Take out current CIC:
•Kombi dash plastic (just pull it out from borders)
•Dash trim (you can pull it out after taking out Kombi dash)
•Center base plastic (this is the bottom center head unit plastic, also pull it out, no screws)
•Center console (after everything is out, here are some torx)
•Head Unit (unplug cables)
•Screen Display (torx and video cable)
•iDrive Controller ( I have no pics for this, but it’s really easy ☺ )
Step 2.- Install your new NBT system (in order to install the new display, you have to replace your current video cable with the new one)
Step 3.- Coding
•Add 609 and 6NS to FA and write FA to car (when this part of coding is done, you’ll notice some error codes in kombi and display, your date/time won’t work, vehicle information, etc. tha’ts why you have to Flash your NBT in next step)
•Flash NBT
-Flash NBT (use VIN matching NBT FSC Codes - normally Donor VIN). This part has a step by step explanation in other forums but I can't find it.
-VO Code Kombi or Dkombi
-FDL Code NBT => KOMBI_CIC = kombi_low and NBT => BASIS_KOMBI_MMI_LIST = aktiv if car has Basic Kombi
-FDL Code Dkombi => KOMBI_AUFLOESUNG = aktiv if car has basic Kombi
Done!
This is my first guide and I hope it's helpful for everyone who is interested in retrofit NBT. You can PM me anytime if you need help buying the right parts and PM shawnsheridan or opasha for coding
      01-11-2015, 10:52 PM   #2
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
Impressive work.
Amber or Red Rear Turn Signals? Vote/have your say: LINK. Post your MPGs 100L/km here: LINK X5 F15 Engines Compared LINK
Take the BMW X5 F15 Survey: LINK See the Results: LINK N57 Diesel Tuning Chips Compared LINK
      01-11-2015, 11:25 PM   #3
kkakonn
kkakonn's Avatar
612
Drives: M4
Awesome, such a difference!
Follow me on Instagram!
      01-11-2015, 11:27 PM   #4
ocman
Drives: 2015 X5
I thought 10 display is standard for all x5?
      01-12-2015, 06:18 AM   #5
LatinBimmer
Peru
135
Originally Posted by MattBianco View Post
Impressive work.
Thank you buddy!
      01-12-2015, 06:19 AM   #6
LatinBimmer
Peru
135
Old CIC in the F15 is terrible!
      01-12-2015, 06:22 AM   #7
LatinBimmer
Peru
135
That's standard for most countries...not for Peru, and many others were you pay higher prices to
      01-12-2015, 07:09 AM   #8
Wobbles
Singapore
298
Drives: F02, F13, F15
Congratulations LatinBimmer! I'm impressed beyond words! Since you've successfully done this, I reckon the next step MAY very well be the HUD retrofit project
It's fantastic work - congrats again!
      01-12-2015, 07:15 AM   #9
LatinBimmer
Peru
135
Thanks buddy! I don't think I'll go the HUD route...maybe the great 6WB like opasha...
      01-12-2015, 08:42 AM   #10
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Well done, Enrique . Thanks for taking the time to post this, buddy. I'm sure it will help a lot of people interested in the upgrade.
2014 X5 50i X-Line // Mineral White
      12-27-2015, 08:41 AM   #11
dhlair
Drives: 2015 X5 F15
Just what I've been looking for. Same problem with men in Panama. Can you send me a list of parts needed for complete retro? Thanks!
      12-27-2015, 08:42 AM   #12
dhlair
Drives: 2015 X5 F15
Same problem with mine! Is what I meant!!
      01-04-2016, 02:43 PM   #13
dhlair
Drives: 2015 X5 F15
Hi Latin Bimmer, bought mine in Panama and have same issue! European specs. Are those the only 3 parts you need to perform the retrofit? At a parts store in Canada, they gave me a long list parts to perform this. Are these the only ones I will need or does this require certain other options? Really appreciate the help.
      01-04-2016, 03:06 PM   #14
1230vani
1230vani's Avatar
Drives: G05 40i LCI
Because this being possible my navi pro screen and the whole unit along got stolen.
P111572.00
      08-08-2017, 09:59 AM   #15
Hillstate
Drives: x5
Anyone knows where to buy the stuff?
      08-08-2017, 12:21 PM   #16
d_v_o_1
Drives: F15
They are all over eBay, most coming from Latvia, Russia, and Lithuania area. I did a swap on my last E71 and it worked out well.
      04-11-2018, 11:08 AM   #17
mrgonzalesdc
Drives: BMW X5 f15
Muy bueno!
      04-11-2018, 11:27 AM   #18
mrgonzalesdc
Drives: BMW X5 f15
Thumbs up
Muy buen trabajo!, me gustaría hacer lo mismo en mi X5 F15 y me parece que estas en Perú al igual que yo, podría contactarte para que me des algunos datos de como conseguir lo necesario?
      04-11-2018, 04:27 PM   #19
1230vani
1230vani's Avatar
Drives: G05 40i LCI
A lot of used ones for sale are actually stolen, thats my problem with it
      08-19-2019, 10:14 AM   #20
supermoc
Drives: BMW X5 M50d
My 2014 X5 has NBT with 10.25 screen, If I retrofit NBT2 EVO without changing the screen, do I need to change the video cable? I remember someone says NBT2 evo has different voltage output.
      08-19-2019, 10:47 AM   #21
CatalinP
Drives: BMW X5 F15 2014 3.0xd
You need to change the screen...
      08-19-2019, 10:55 AM   #22
RED_Y_
Drives: 2014 X5 3.5d
Depends if you are retrofitting touchscreen or not. Check here
https://f15.bimmerpost.com/forums/sh....php?t=1593428
xbimmers
