BMW X5 and X6 Forum 2014-Current
      12-30-2014, 06:14 PM   #1
LatinBimmer
Peru
135
Drives: X5 2014 Sparkling Brown
Success!!!! NBT retrofit in F15!
Just a few lines to let you know that today I successfully finished nbt retrofit in my F15.
As some of you know, my F15 came with standard 6.5" display CIC...and that's really stupid from dealers...how much do they save? $1,000?...anyway, it's done now.
I will write a full thread with instructions and everything needed later, but I just want to THANK now two amazing buddies: Omar and Shawn, who helped me with all coding and flashing stuff, now I have a fully working NBT, no issues at all
Happy New Year!!
      12-31-2014, 12:38 AM   #2
usumega
Drives: BMW F16 30d
Hello.
I have exactly the same problem than you: my F16 European version doesn't has NBT and I want to retrofit it when will delivered early in January, so i can´t wait for your review!!!.
Is very dificult to do that?
      12-31-2014, 01:13 AM   #3
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Originally Posted by usumega View Post
Hello.
Unless you are as skilled as gatordent, you will need help to open up your iDrive, remove panels, and get coding done.
2014 X5 50i X-Line // Mineral White
      12-31-2014, 05:12 AM   #4
tnikolov
tnikolov's Avatar
Bulgaria
69
Drives: BMW X5 40d,Porsche 911 Turbo S
How do you guys check if its NBT or CIC?
On order - 2017 F15 X5 40d M-sport Individual
Current - 2016 Porsche 991 911 Turbo S w/ Aero Kit
Retired - 2015 F15 X5 50i, Mocha Nappa, M Sport Wheel, Night Vision w/ human recognition, Harman Kardon
Retired - 2011 F10 550i xDrive
      12-31-2014, 05:14 AM   #5
paicapo
paicapo's Avatar
265
Drives: E92 M3, F15 X5 M-sport
Same question here, watts the difference?
The best car ever: E34 M5 3.8l daytonaviolettmetallic hos Mälardalens Ventilationsceneter
      12-31-2014, 06:01 AM   #6
opasha
opasha's Avatar
1329
10.2" iDrive (NBT) vs 6.5" iDrive (CIC). Only select countries, unfortunately, have the option of the 6.5", so they have no choice but to either retrofit or spend a lot more money for the 10.2" iDrive. I don't really know their full option selection for their countries, but again BMW isn't very fair across the global market. paicapo and tnikolov, you two are fine with the 10.2" NBT. So far, I've only seen one member in Bimmerfest from Hong Kong and LatinBimmer have the 6.5" CIC iDrive.
      12-31-2014, 06:06 AM   #7
tnikolov
tnikolov's Avatar
Bulgaria
69
Perfect, thank you @opasha! It's really mean to have that beautiful beast with 6.5" CIC only. Congrats to the OP for the retrofit!
      12-31-2014, 06:12 AM   #8
opasha
opasha's Avatar
1329
You're very welcome. I agree, that's why LatinBimmer made the switch. Poor guy had to wait for the parts for a while and had to go through a few headaches in order to install and code correctly, so his DIY will be very helpful to many members who have the 6.5" CIC. Also, shawnsheridan helped much more than me in making sure everything was flashed/coded properly with the HU_NBT ecu . This community would be lost without his knowledge on retrofit coding.
      12-31-2014, 08:25 AM   #9
usumega
Drives: BMW F16 30d
Hi Opasha.
In no case I will do the mechanical part, because I'm not so skilled , but I dare to coding with your help if it is not too much to ask.
My car is delivered on January 9 and until then try to locate someone who can do the installation in Spain.
Happy New Year!!!!.
      12-31-2014, 12:22 PM   #10
opasha
opasha's Avatar
1329
Hi Opasha.
Happy New Year!!!!.
Send me a PM once you get your car. You'll need an ENET cable, full data files, and also someone to externally power your car for you through jumper cables in case the HU_NBT will have to be flashed (most likely this will be the case since LatinBimmer had to do it).
Happy New Year to you as well .
      07-04-2020, 04:34 AM   #11
kikocarv
Drives: BMW X5 F15
Happy New Year!!
Hi LatinBimmer,
I to had the CIC from factory on my 12/2016 X5...
Some guys upgraded it to a NBT HU, but I have no data transfer active or connected apps. Shouldn't data transfer be active since the car comes with a TCB? Or does the unit has it's own built in sim card?
I have a connected drive subscription (connected pack). I can use remote app to lock and unlock my car.
I can enable the Bluetooth tethering but it does nothing because there is no app to use the connection. No weather, no news, etc...
I would like to have RTTI and all other services, if possible, not using the Bluetooth tethering.
Can you help me?
      07-04-2020, 05:47 AM   #12
devlinsky
Drives: F15 M50d / ex E90 335i / Panda
That's amazing, my car is June or July 2014 and came with NBT. European market.
xbimmers
