M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      12-26-2014, 08:00 PM   #1
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Help - Removal of Grille with Night Vision
Was helping my buddy remove his grille today and was unable to remove the drivers side which has the NV camera mounted. We were able to release all of the clips on the grille, but still couldn't get it out. Felt like there was still something holding it in, but was unable to see what. Anyone know how this is done?
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      12-26-2014, 10:15 PM   #2
bronch
Waiting for the sun
bronch's Avatar
66
Drives: 2018 M240ix
What year M5, LCI model? Not sure if this helps, see last post. Otherwise, you may consider contacting IND and see if they can help you out. Good guys there.
2012 E92 M3- Miss her.
2015 F10 M5- Land yacht, but miss her too!
2016 991.1 GT3- Woohoo!
2018 M240ix- Daily driver. Still Woohoo!
      12-26-2014, 10:22 PM   #3
bake
bake's Avatar
It is actually my friends 535, but since hardly anyone opted for night vision on non-M cars, I figured I would post on the M5 forums. Seems like a lot more M5 guys splurged and got this option.
Bake
      12-26-2014, 11:35 PM   #4
bronch
Waiting for the sun
bronch's Avatar
66
Drives: 2018 M240ix
I think the link may still help since the grills are the same. However, there's a difference in removing the LCI version vs. pre-LCI version. At least on the M5 models. If that doesn't help, than I suggest you try to contact one of the IND people on this site who are vendors. They are very approachable and helpful.
      12-27-2014, 06:52 AM   #5
Spinny02
Spinny02's Avatar
Drives: '14 M5 CP Dinan Stage 2
I have tried many times... I gave up. Boots was going to help me install the RPi scoops but then I had the Dinan intakes installed ( has similar scoops) so I have no need to take the grills off any more.
      12-27-2014, 01:36 PM   #6
variable229
Drives: M5
I have night vision on my car (2015 LCI version) and did a grill swap out to fit the IND ones in. There is a screw nut that you have to remove from the top of the car that holds onto a bracket with the front grill. I yanked mine out previously (old grill) and broke a tab. But you can learn from my lesson.
Open the hood. Remove the rubber grommet from the front bumper on the driver side with night vision (you don't have to take off the whole thing, just lift 25% of it up to move it out of the way). There is a plastic housing that covers the headlight assembly. This housing covers where the hood hooks into to close.
You want to pop off 2 plastic tabs of the plastic housing so you can lift that up. It will expose a hole near where the bumper and where your night vision assembly would be. You need to remove this 1 hex nut. I used a driver and extension to unfasten it. After that is removed, use two hands grab the grill and yank it out.
      12-27-2014, 01:57 PM   #7
bake
bake's Avatar
Thanks. I will take a peek next time I am with my buddy. If you can snap s pic pointing to the point fact location you are referring to, that would be awesome. Thanks again
Bake
      12-27-2014, 04:37 PM   #8
variable229
Drives: M5
Thanks. I will take a peek next time Zi am with my buddy. If you can snap s pic pointing to the point fact location you are referring to, that would be awesome. Thanks again
You want to remove the screw from the hole below the plastic.
m5post
