BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
European Auto Source (EAS)
      12-08-2014, 10:07 AM   #1
Zzhou
Zzhou's Avatar
Drives: 2012 E92 SSII ZCP DCT
Question After market pads= no rotor change?
I run about 10 track days each year, and now my front stock rotor is below min sickness. I took the car to the dealer and asked them to replace my rotor, but they refused it because I run after market brakes. Wonder if the same thing happened to you guys?
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER
      12-08-2014, 11:42 AM   #2
Evolve Automotive
BimmerPost Supporting Vendor
Evolve Automotive's Avatar
Drives: E46 M3 . E90 M3
i always change back to stock pads and they have replaced my rotors a few times no questions asked. I also think its depends on what dealership you go to
      12-08-2014, 12:34 PM   #3
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
It's due to the fact the dealer has to send back the pads and rotors to BMW once they are replaced u den warranty and are measured back at BMW for min thickness. If they fail to meet min dealer does not get reimbursed. Rotor replacement requires worn pads as well.
      12-10-2014, 12:55 PM   #4
Zzhou
Zzhou's Avatar
oh....looks like I need get a set of used pads..haha
      12-10-2014, 01:35 PM   #5
Amirsm3
Amirsm3's Avatar
514
Drives: 2011 Space Grey e90 M3
lmao I may have a set you can have. Just pay me shipping.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970
      12-16-2014, 07:58 PM   #6
Hierlevelz
Drives: 11 AW E9X M
Did you measure the thickness on your own? What's is the serviceable limit for rotors and pads?
      12-18-2014, 09:22 AM   #7
Zzhou
Zzhou's Avatar
yes, I measured the front. the min is marked on the rotor I believe, about 22.8MM
      12-19-2014, 11:45 PM   #8
Hierlevelz
Drives: 11 AW E9X M
I'm assuming that is the overall width? Measured from the inboard most to the outboard most face of the rotor? I have to get me a 0-1" outside micrometer to measure my rotors. I don't recall if rotors and pads are covered under the maintenance program though. Seems to be at the discretion of the SA/Dealership.
      12-20-2014, 11:27 AM   #9
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
Min thickness Specs listed in Mitchell Pro:
"New brake pads may only be installed if the brake disc thickness is greater than or equal to the minimum brake disc thickness (MIN TH) (not including M vehicles).
In case of M vehicle and perforated brake discs new brake pads may only be installed if the brake disc thickness is greater than the minimum brake disc thickness (MIN TH).
Minimum brake disc thickness during general inspection (GI):
Nominal size thickness minus 2.4 mm
(Not applicable to perforated brake discs and M vehicles)
M vehicles and perforated brake discs:
Nominal size thickness minus 1.6 mm"
The Nominal (New) thickness is 30 mm front minus 1.6 mm = MIN TH of 28.4 mm (1.11811 inches).
You will need a larger micrometer. You will have to hunt for a brake rotor specific micrometer. The pointed tip helps to measure the actual depth of the grooves, if present.
This video shows the micrometer:
      12-20-2014, 03:27 PM   #10
Hierlevelz
Drives: 11 AW E9X M
Thanks...So I'll need to get me a 1-2" mic
      12-20-2014, 06:36 PM   #11
kenwelch
Some measure .500 - 1.500 inches. Like in the one shown in the video and have pointed tip(s).
m3post
