R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      12-04-2014, 11:56 AM   #1
C-ARchitect
Drives: Miniature Ferrari
Downpipe DIY?
Has anyone attempted to DIY downpipes on the F8X yet? I've done a ton of N54 downpipe installations, was wondering if it would be a similar process for S55?
Thanks in advance!
      12-04-2014, 01:06 PM   #2
Mandi90TT
Drives: BSM 6MT M4 F82
Would love to see this myself
2015 Black Sapphire Metallic 6MT M4
      12-09-2014, 08:46 AM   #3
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Yea anyone working on this? I want to do DP but will likely have to do self install and a yearly swap. Want to see what I'm in for.
      01-20-2015, 07:06 AM   #4
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Bump - So has anyone done downpipes themselves? Just wondering if it's a pretty easy job or not. Seems like it should be.
      01-20-2015, 08:51 AM   #5
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
Akrapovic has a fairly comprehensive install posted on their site. I plan to do it myself when I get them. But I do have a lift in my garage which makes jobs like this easier.
      01-20-2015, 09:14 AM   #6
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Yeah I don't have a lift but I have access to an oil change pit which may work.
Akra is the only one with flex pipe. Wonder if its worth the extra $$.
      01-20-2015, 10:01 AM   #7
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
oil change pit should work just fine!
that's why I decided to go with Akra. They always make a very well engineered product - perhaps over engineered but I'll have peace of mind knowing my downpipe connections to the turbos aren't under unnecessary stress.
      01-20-2015, 10:04 AM   #8
NorCal f80
Drives: M3
Eisenmann has flex and for sure Zima does as well. I didn't go with Zima version 1 because the diameter gets small although I don't think it makes much difference. Their version 2 are almost done and will have flex of course. Oh yea much more cheaper cost than Akra or Eisenmann of course.
      01-20-2015, 10:07 AM   #9
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
I could have sworn ER were selling for like $900 but now they are closer to $1100. At that point you may as well get Akra or apparently Eisenmann w/ flex pipe ?
      01-20-2015, 10:07 AM   #10
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
When I checked I could only find Akra or Eisenmann with flex and since they were similar price I went with Akra since I have the akra exhaust ...
      01-20-2015, 10:35 AM   #11
NorCal f80
Drives: M3
Zima version 1 ----- http://f80.bimmerpost.com/forums/sho....php?t=1036265
If I recall they were around $1000
Their version 2 doesn't taper down so much and are going to be priced the same.
version 2
      01-28-2015, 09:14 AM   #12
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Those are expansion bellows in the OEM exhaust, it's not a flex section. It's in place because of the added heat from the OEM cats. The restriction from the cat traps heat which is why they are generally recommended for catted downpipes. A stainless steel pipe will actually flex quite a bit without the expansion joint and the expansion joint is actually in place to preserve the seal on the catback connection (hence its location).
We've sold thousands of downpipes for various different turbocharged platforms and have never had a turbo or a downpipe fail due to a lack of expansion joint. You actually increase the risk of failure of a part when you start adding components. Any long time mechanic can confirm that most exhaust failures happen at the flex section or the cat.
As far as the install goes, it's pretty straight forward and there's definitely more clearance than the N54. You don't have to unbolt the steering rack and the v-bands are more accessible. The only major difference is the catback has to be removed/lowered/pushed aside in order to remove/install the new pipes. The E90/E92 catbacks would move back without having to unbolt the entire assembly but the F80/F82 is bolted up pretty tight.
      01-28-2015, 09:57 AM   #13
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Guessing it will be even easier w/ MPE since my stock setup is hacked in half?
      01-28-2015, 10:12 AM   #14
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
That should help!
      01-28-2015, 11:08 AM   #15
WVUDrJay
WVUDrJay's Avatar
262
Drives: 2015 M4
That's good info as there had been many posts describing these as flex joints designed to not put stress at the connection.
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
      01-30-2015, 04:04 AM   #16
SOM3
Drives: SO F80
Well you can belive that or look at TOP ehxhaust manufacturers like Akrapovic, Eisenmann etc. and see that their DP come with expansion joints.
You be the judge.
      02-18-2015, 01:30 AM   #17
///M.Tonee
///M.Tonee's Avatar
Drives: Porsche 991.1 GT3
Any DIY videos for the downpipe install yet?
Garage: 2015 991.1 GT3 | 2016 AMG GTS Sold | 2015 C7 Z06 Sold | 2015 M4 SO/6MT Sold
Instagram: M.Tonee
      02-18-2015, 08:40 PM   #18
WERKE
President Directeur General
WERKE's Avatar
Drives: F82 M4/ E92 M3 ESS/F-type R
+1
f80post
