BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
EXXEL Distributions
      12-01-2014, 07:46 AM   #1
af908
Drives: 2008 M3
2008 iPhone 5 and idrive
Guys,
My iPhone 4s just shit the bed. I will be upgrading to the iPhone 5s. Will I sti have full access to my music library on my idrive just like i had with my iPhone. 4s? Keep in mind this car is an 08 m3 and has the older idrive unlike the 2009 and up.
I apologize if this question has been asked before. I'm in a rush and my search didn't bring up my answer.
      12-01-2014, 04:14 PM   #2
Da Hapa
Drives: 2008 E90 M3 6MT
Both my old Iphone 5 and current Iphone 6 work as designed in my 2008 E90 M3 with the same shitty, lame version of Idrive you have.
Hope that helps.
      12-01-2014, 05:39 PM   #3
70X200
Drives: 2008 BMW M3 E92
Mine works just fine. You will need to buy an adapter to go from the 21 pin connector to the new fancy connector thats all.
      12-01-2014, 06:45 PM   #4
badbeef
Drives: 3 pedals
Related question.. I have a 2011 with the snap in iPhone 4 adapter. Can I just get the y cable with the firewire plug and leave the plug in adapter as is? That snap in adapter is a pain, and I like to keep the phone charged anyway.
      12-01-2014, 10:32 PM   #5
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
That's a Lightning connector (FireWire is a completely separate entity), but yes the 30-pin female to Lightning male adapter should work through the cradle just fine as long as the cradle design doesn't prevent the adapted from physically connecting. But if you have a 2011, why bother with the cradle at all? Do you need to keep the USB port in the glovebox free for some other device? If you have a 2011.5 you can use a regular Lightning to USB cable; if you have a 2011(.0), you can use a Y cable.
Also note that even if you have the iPhone 4 MEDIA cradle (assuming you have a 2011.75 with BMW Apps), the "iPod Out/PlugIn" and video playback features will not work with an iPhone 5.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      12-02-2014, 02:17 AM   #6
SenorFunkyPants
SenorFunkyPants's Avatar
Drives: 2019 M5
Would something like this work? (iphone 5 and 5s only)
http://www.amazon.co.uk/Vktech-Outpu...for+iphone5S+5
I have one on order but won't be allowed to try it out untill xmas.
      12-02-2014, 07:41 AM   #7
badbeef
Drives: 3 pedals
Very helpful post. Thank you. I have a 2011.75 with BMW apps. I was not aware that a plain old lightning to usb cable (and not a y cable) would work. I will give this a try.
      12-02-2014, 10:26 AM   #8
calbear13
Drives: 2013 SSII E92 M3
Why don't you just use bluetooth for music? It's free in comparison
      12-02-2014, 11:12 AM   #9
jphughan
jphughan's Avatar
Yep, USB will sound better than a Y-cable too because it uses digital rather than analog delivery to the car. In fact I believe even the cradles use analog audio because they predate the 2011.5 cars that supported digital audio, though the MEDIA cradle may be an exception to this. In any case, USB might well sound better than what you're doing now.
And yes, as mentioned above, Bluetooth audio streaming is also available as of 2011.5, which is much more convenient and avoids the potential for you to forget your phone in your glovebox. It doesn't sound QUITE as good as USB since bandwidth is more limited, so I still connect via USB for longer trips, but Bluetooth being digital still means it sounds as good or better than using AUX via a Y-cable, which is why I use it 95% of the time.
      12-02-2014, 11:18 AM   #10
jphughan
jphughan's Avatar
This is essentially a Y cable designed for an iPhone 5, so it would spare you having to purchase the 30-pin to Lightning adapter. I can't see why it wouldn't work, though again on a 2011.5 or newer car it would be unnecessary and suboptimal.
      12-02-2014, 11:37 AM   #11
SenorFunkyPants
Drives: 2019 M5
If you are not bothered about charging your device then there are also several bluetooth units that can fit into the glove box and pair with your iphone (for pre- 2011.5 cars).
      02-03-2015, 08:22 AM   #12
mmbv1000
Drives: G35 Coupe
Hi guys - I posted in another sub forum but thought I'd get more response here. I have an 08 and just upgraded to an iPhone 6. I was using the y-cable previously and purchased a 30 pin-to-lightening adapter and that doesn't seem to work. I've also tried using just the usb, but get a "device not supported" message. What am I doing wrong?
      02-03-2015, 12:06 PM   #13
///Mvy
Drives: 15M3 + 08GT3
Sorry, can't answer your question as I'm having the same issue trying to connect with my adapter. Is yours a true Apple brand adapter?
Anyone tried to use this device or something similar?
http://www.amazon.com/CoolStream-Blu.../dp/B00GHUHMUS
I'm thinking about ordering one to hook up to my Y-Cable and hopefully have Bluetooth audio.
      02-03-2015, 12:27 PM   #14
OneSickM
OneSickM's Avatar
122
Drives: M3
Sub'ed ...would like to know this thing work as well
      02-03-2015, 12:44 PM   #15
///Mvy
I bought the CoolStream in the link above. I'll let you know if it works. Some said it won't work with BMW but I'm going to try anyway with Amazons great return policy.
Also found this: http://www.amazon.com/ViseeO-Tune2ai.../dp/B00B52LLJ6
Price point is a bit higher but supposedly it will work. Some said it would even tie into the idrive for controlling the iPod like the factory Y-Cable. It's advertised to integrate with Audi MMI so maybe it would play with iDrive as well.
      02-03-2015, 12:49 PM   #16
///Mvy
And then I found this....http://www.amazon.com/gp/aw/d/B00R3A...=AC_SX230_QL60
Advertised to work with BMW and a reviewer claiming it works well with his 07' 335i.
I'm canceling my order for the CoolStream and ordering the above.
      02-03-2015, 01:58 PM   #17
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
OP has a CCC idrive, no Bluetooth streaming.
      02-03-2015, 02:14 PM   #18
mmbv1000
Drives: G35 Coupe
I've heard good things about the Viseo and might go with this if I can't find a hardwire solution.
      02-03-2015, 02:15 PM   #19
mmbv1000
Drives: G35 Coupe
I believe I am, but not entirely sure since I purchased it cheap, online. Certainly looks like one....
      02-03-2015, 07:08 PM   #20
jphughan
jphughan's Avatar
http://www.amazon.com/CoolStream-Blu.../dp/B00GHUHMUS" rel="" target="_blank">http://<a href="http://www.amazon.co...B00GHUHMUS</a>
You almost certainly need one of the two genuine Apple adapters. The reason is that the Apple ones have an audio DAC chip in them, which is important because Lightning now only outputs digital signals, whereas CCC iDrive requires an analog audio signal. The DAC converts the iPhone's digital audio into analog audio before sending it out the 30-pin connector (and is why these adapters are so expensive even by Apple standards), but if you have a Lightning to 30-pin adapter that only remaps pins to allow you to connect via USB and charge rather than having that DAC, it won't work.
If you're going to be buying a new adapter anyway, I'd recommend the more expensive one that actually includes some cable length rather than the plastic block version. The reason is that the latter might not connect to your iPhone properly if you have a case, whereas the one with cable length has much less plastic around the Lightning connector side.
Once you've got the proper cable, the 08s will continue to need the Y-cable; you'd simply add the adapter to the chain.
///Mvy, Tune2air is known to work well and even allows playback control and I believe song metadata display. The WMA1000 + a Y-cable is equivalent to the 3000B you purchased. The WMA2000 is for cars that actually accept the audio signal over USB, which the pre-2011.5 cars do not, and the 3000A is specific to Audi models, apparently.
      02-03-2015, 07:29 PM   #21
mmbv1000
Drives: G35 Coupe
Awesome - very helpful. thanks, all, for the help!
      02-05-2015, 05:19 PM   #22
Mvy
Drives: 2008 E93 M3
Dude you stole my handle ;-)
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive...
m3post
