10-01-2014, 03:27 PM | #1 |
Rep 38
Lithium Ion Battery Charger Availability?
I called a BMW dealer about buying a trickle charger for my M4's lithium ion battery and was initially told that there is only one genuine BMW charger for all models. When I pointed out that a lithium ion battery requires a specialized charger he told me that he would have to do a bit of research. A short time later he called back and said BMW does not offer such a charger, but that I should look for one on the after-market that has a 13.6 volt setting.
Does anyone have information about the availability of an appropriate charger? Can anyone recommend a specific charger? Thanks. |
10-02-2014, 10:43 AM | #2 |
Some dude
91
Rep 1,780
I'd check with Deltran Battery Tender, first. They have Lithium Iron Phosphate batteries and chargers for them as well. I'd give those guys a call and see whether they're appropriate for the new BMW Li-ion battery. http://batterytender.com/chargers/
They claim they're the manufacturer for BMW, Harley, Lotus, and others. More info on charging Li-ion batteries: http://batteryuniversity.com/learn/a..._ion_batteries
RRT
E92 335i/6MT with stuff and things |
10-02-2014, 11:52 AM | #3 |
Rep 984
See my post here, this is direct from BMW NA. BMW themselves do not offer one at the moment.
http://f80.bimmerpost.com/forums/sho...7&postcount=49
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
10-02-2014, 12:00 PM | #4 |
Rep 555
I'm assuming you all want this for use during car storage, no?
My car will have limited use, if any during winter months. Can you recommend what things you would do during this time? Intermittent start ups? |
10-02-2014, 08:05 PM | #5 | |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
http://www.ctek.com/int/en/chargers/LITHIUM%20XS
....Life is too short to drive boring cars
10-07-2014, 08:53 PM | #6 | |
524
Rep 2,146
I own a Ctek charger and tester (still brand new) and don't know if it will work on my M4?
10-07-2014, 09:04 PM | #7 |
Rep 240
Are you 100% sure, i don't think the M4's or any BMW (maybe an i8) uses an Li-Ion battery. Open the hood look at the battery if you see liquid in the cells it's not a Li-ion. If it was a true LiPo it would super expensive and the charging circuitry very sophisticated indeed. Perhaps it's its an advanced glass mat battery or AGM (not a LiPO) good battery over conventional wet cell and you still need a very good charger as not to ruin the battery which is easy thing to do.
10-07-2014, 09:08 PM | #8 | |
524
Rep 2,146
http://www.ctek.com/int/en/chargers/...20AND%20CHARGE
10-07-2014, 09:19 PM | #9 |
Rep 240
COLD/AGM: Charging in cold conditions and AGM batteries - Yes, this charger will work for an AGM battery most likely what's in the M4. Come to think of it, it's in the trunk right, then it would have to be an AGM battery as AGM don't out gas like a conventional wet cell, hence you can putt it in the trunk safely. They are popular in boats and RV's as well. Take good care of the battery a good AGM can set you back 250+ dollars to replace and you definitely charge it correctly. My RV uses AGM's and yes during say we say learning process I've ruined a few and was not fun replacing them.
General rule of thumb for AGM's 1. Never over charge them - so you need a good charger that is AGM aware and be sure to put the setting on the charger for AGM 2. Never let it get under the manufacture min voltage some as low as 12.3v, check the manual that came with it. |
10-07-2014, 09:27 PM | #10 | |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
See this thread http://f80.bimmerpost.com/forums/sho...d.php?t=964593 Also see: http://www.autofocus.ca/how-to/techn...heir-batteries And to answer your cost comment (from the link above): "We figured a high-tech battery like this wouldn’t come cheap, and a quick call to a local dealer revealed the projected cost of these batteries is a little over $1,100."
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
The_Werm212.00 |
10-07-2014, 09:32 PM | #11 |
Rep 240
holy crap, wow - I'm super impressed. I feel better about the sicker price. Least I see where the money is going. Is great but a little scary too to keep this properly charged for winter storage. So easy to ruin a LiPo. Once I get my hands on the battery specs, I might just design my own charger to be safe.
10-08-2014, 01:46 PM | #13 |
X3M Comp
444
Rep 718
10-08-2014, 01:54 PM | #14 | |
524
Rep 2,146
11-20-2014, 03:15 PM | #15 |
Rep 1,732
I bought the Ctek Lithium charger and it is awesome. The charger is very smart.
papasmurf_m3454.50 |
12-02-2014, 01:09 AM | #16 | |
Rep 2,108
Can you post pics?
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
12-02-2014, 01:14 AM | #17 | |
Rep 1,732
Will post some pics tomorrow. |
12-04-2014, 01:01 AM | #18 | |
Rep 2,108
12-04-2014, 01:05 AM | #19 |
Rep 1,732
Unfortunately no. It needs to be plug in.
12-04-2014, 12:25 PM | #21 |
Rep 641
Do the F80 systems give any info on battery condition eg state of charge via the idrive as the lithium battery is supposed to be a smart battery.
M2 competition, Alpine White
Previously Owned : X3 M 40i, F80 M3 Comp Pack, DCT, Yas Marina Blue, F80 M3, DCT , E92 M3 Comp Pack, E92 M3, Z4MC, E46 M3 CS, E46 M3 |
