10-01-2014, 01:23 PM | #1 |
Rep 139
Wait for service indicator, or do oil change now?
Hey Guys,
My service indicator is showing a due date closer to mid 2015, even though I have had the car for close to 3k miles. In the spirit of being proactive, rather than reactive (wanting to change every 3.5k miles) when it comes to at least the oil change...should i take it to BMW and request an oil change? Is 3.5k interval too quick? Should i maybe change every 5k? or more....? Any restriction from BMW as to changing oil outside of the computerized intervals?
'13 M3, Mineral White, 6MT (back to my addiction)
'15 991.1 GT3 (sold) '77 911s, Targa Red, Coupe (sold under duress) '13 M3, Melbourne Red, ZCP(sold) '08 M3, Space Grey (sold) |
10-01-2014, 01:34 PM | #2 |
The Hammock Man
493
Rep 593
Drives: X3MC, X3 M40i, E93 M3
Every 5-6k or minimum once a year (on low mile M's)... really no reason to change the oil more often.
- '20 X3MC | Alpine White | Black Alcantara/Midrand Beige | loaded | 295/265 PS4S - '09 E93 M3 | Alpine White | Bamboo Beige Novillo | DCT | loaded | Chrome M220 Wheels - 275/255 PSS |
10-01-2014, 01:34 PM | #3 |
Rep 878
If you're trying to get it done under some sort of maintenance plan, they'll likely turn you away and ask that you wait for the service interval to come due or bring it by shortly before. BMW extended the oil service intervals out the way they did to cut costs; if you take it in 3x's as often as it's scheduled, BMW loses money. Can't hurt to ask though, but be prepared for a 'No' from the service advisor.
Changing it on your own dime? Do it every 5K miles.
-WJV
10-01-2014, 02:24 PM | #4 |
689
Rep 6,854
Your oil filter will make the biggest difference. I always suggest using the best oil filters that you have available as they are really the big difference in how clean your oil stays. I still prefer to change my own oil every 5k though as I tend to drive my cars very hard.
-Anthony
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
10-01-2014, 02:53 PM | #5 |
Rep 11,891
3.5k is way too aggressive for standard street driving unless you idle your car excessively.
If you're using OEM oil, I would stick with the recommended interval. Others tend to change at ~7500 or 5000 miles. |
10-01-2014, 06:38 PM | #6 |
Rep 837
Why are people so paranoid to have their oil change early beyond the BMW recommend 15,000 mi or one yr? That's just a waste of good oil to change every 7,500 mi
10-01-2014, 08:01 PM | #7 | |
Rep 3,393
I do it every 5000-7500 miles. With how finicky some of these engines can be, the cost of more frequent oil changes than 15k miles is worth the extra costs to me. |
10-01-2014, 09:57 PM | #8 | |
Rep 4,488
OP, I track my car 8-10 days per year and do about 10K miles/year. I change every 7500 miles, and my Blackstone report said that my oil was "good compared to all cars, but great for a car that sees track time." They also saw no indication that I should be changing my oil more often. Others using their cars similarly and following the same interval have gotten similar responses from Blackstone. I could probably even do 10K, but I like doing it halfway between the CBS intervals and to me 10K intervals aren't worth the cost savings. Also note that for the time interval, the CBS shows it as two years out even though Ultimate Service will give you a free change after a year. That is IN ADDITION to your mileage-based change whenever that comes up. I hit the one-year mark before I hit 15K miles, so I got a change where they didn't reset my CBS, and then about 1500 miles later I got another one. Seemed a little weird to me, but it was on BMW's dime.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
10-02-2014, 11:44 AM | #9 |
Rep 11,891
10-02-2014, 07:16 PM | #10 |
Rep 468
My $0.02...
3.5k intervals gets you nothing...likely a waste of time and money UNLESS the car sees extreme conditions (driving through the desert, on the beach, tracking every day, etc.)...kind of like VividRacing's comment about driving the car hard. I also respectfully submit that filters are important, but they are not the most important factor. The primary degradation mechanism for oil (including synthetic) is oxidation. Oxidation is a chemical reaction between the oil and O2 which usually occurs at high temperature and over a relatively long period of time. The best way to keep your oil in good condition is to make sure you do not run with too little oil (builds up heat), don't over temp the engine (again, too much heat), and don't overload the bearings (heat is still the enemy). Synthetics are much more resistant to oxidation than mineral oil, but they do still degrade. Most of the black color that oil takes on is the by product of oxidation (carbon deposits play a role, too). Mileage, driving style, and time all affect how long your oil will retain the target viscosity range (the most important lube property). I recommend you go 10k miles, have a Blackstone report (or other analysis) and use the actual information from your actual car and your actual driving style to determine the right intervals. When treated properly, these engines can go 15k miles between changes just fine. Don't succumb to scare tactics and one off stories (including this post). GET DATA and make an informed decision. |
10-02-2014, 10:08 PM | #11 |
Rep 409
Well I change it every 6 months, one I do, the other BMW.
It's easy to do yourself. No reason not to. I am used to changing my oil frequently with my other cars I have owned and with this car and the sensitivity of the engine it sure cant hurt IMOP. Since no one has discovered factually a remedy for the bearing problems, then saying that changing the oil frequently is a waste of time, is simply an opinion. Last edited by Sinful; 10-02-2014 at 10:15 PM.. |
