BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      08-18-2014, 12:55 PM   #1
FOURSIXTEEN
FOURSIXTEEN's Avatar
94
Drives: 08' e90 M3 6MT / 97' e36 M3
Replacing rod bearings after blackstone report
So i just received my report back it is attached below. 08 e90 m3 with 78k miles no track events and car has lived in texas its whole life. i am the second owner with the first being a local doctor here in the DFW area. I drive fairly aggressive not that that worsened the problem, but just wanted to throw that out there, however i do let the car warm up stationary for ten minutes when cold and drive under 4k till at temp. been changing oil every 5000 miles with the stock stuff, but i am going to motul 0w30 with new bearings.
Texas track works here in fort worth texas will be doing the replacment this next monday. doing coated bearings from EAS and also was told i needed to replace rob bolts so i ordered ARP bolts from EAS as well. parts alone (bearings, bolts, oil) was about $980 after a paid extra for 3 day shipping. I believe i am looking at roughly a grand in labor so lets just say 2k all together.
i will update the tread with the used bearing pictures ASAP on monday as they come out of the car so there is one more reference for everyone to go by. the cost is about what everyone else has mentioned at the 2k range out the door.
      08-18-2014, 01:01 PM   #2
Killerfish2012
Drives: E90 335I, E92 M3
I personally would have just switched to Mobil 1 0W40, and left it at that. Especially if there are no unusual noises coming from the engine. Coated bearings won't give off lead, so future oil analysis won't be able to warn you if there is a problem.
'07 335I w/ Mods
'13 X1 Stock
'11 X3 K&N
      08-18-2014, 01:19 PM   #3
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
+1, sounds like coated bearings might make things worse. I would have at least gone with the WPC treatment, but really who knows.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      08-18-2014, 01:22 PM   #4
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
You start the car and just let it sit for 10 minutes every time? Why? The owners manual specifically states not to do that.
Also, why will you be switching to 0w-30? Never heard of any M3 owners using that grade.
      08-18-2014, 01:52 PM   #5
Gossypiboma
Drives: 13' M3 6MT 18' M3 CS
And why do you think that is? Idling the car to warm up is somehow bad for the motor? There is no reason you cannot let your car warm up by idling besides being aware that the tranny is still cold when you first drive.
      08-18-2014, 02:23 PM   #6
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I was always taught that fuel can more easily contaminate the oil when idling cold; maybe engine design has changed over the years.
      08-18-2014, 02:35 PM   #7
FOURSIXTEEN
94
thanks for the opinion thats a good point.
seriously? seems backwards....
i meant 0w40 sorry my mistake
i got WPC treated bearing from eas
      08-18-2014, 02:42 PM   #8
FOURSIXTEEN
94
WPC coated? will make it worse? i was under the assumption they didnt make it any tighter? but i may be wrong. i figued between all the bearing issues on here and blackstone labs reports that i was easily in the realm lead wise to do a replacement, but if you guys think not thats an important opinion to investigate if switching to 0w40 is all the majority thinks i should do. i just viewed it as preventative maintenance and better to spend 2k then 20k kinda deal.
      08-18-2014, 03:05 PM   #9
W///
W///'s Avatar
7494
Drives: F82GTS, E36/E92M3, Z4M
WPC is good. It's not a coated bearing. You'll be fine if you run that with 0W40, that's the best way to go (IMHO of course).
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      08-18-2014, 03:14 PM   #10
vastano
Drives: F15 X5
4 oil changes ago, my lead reading was 28ppm. After that I switched to 0W-40 and havent had a reading above 5ppm.
I have an extended warranty to 100k so im not sweating it too much if the bearings do fail.
      08-18-2014, 03:22 PM   #11
FOURSIXTEEN
94
Oh okay my mistake on saying coated then, thanks for the correction.
Yeah if i had that i may do the same as well. it may still be worth a try though, i will ask texas track works about it. thanks.
Thanks for all the replies and input guys!
      08-18-2014, 10:45 PM   #12
Killerfish2012
Because of all the alarmists online, people tend to think the engine will just grenade out of no where. Long before this happens, the type of noise your engine will start making will more than forewarn you that failure is imminent. If you don't even have the faintest abnormal engine noise, then you're just throwing away 2K. I've posted this video about 5 times now, but this is what an S65 sounds like in the late end stages of bearing failure:
'07 335I w/ Mods
'13 X1 Stock
'11 X3 K&N
      08-18-2014, 11:13 PM   #13
FOURSIXTEEN
94
Thanks, again this is great feedback and I am considering this too. Thanks for posting this vid. I have absolutely no noise as of now.
It wasn't really the cost of the whole thing but more of the peace of mind, but I didn't realize I may be jumping the gun by a bit
      08-26-2014, 12:48 PM   #14
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
Similar situation here and I just switched to M1 on my recent fill.
Can you post your reports? I'm curious to see what the lead amounts looked like after each sample.
Thanks
      08-26-2014, 01:42 PM   #15
vastano
Drives: F15 X5
Thanks
all but my most recent one is in the mile long blackstone thread.
It can just tell ya:
Mileage Lead PPM
55897 28 <----10w60, switched to 0w-40 after this
60531 6
66690 5
      08-26-2014, 02:27 PM   #16
Flying Ace
Flying Ace's Avatar
4985
Mileage Lead PPM
60531 6
66690 5
wow, thanks for this info. I was more interest in reading their written analysis or whether they attribute the drop to the switch to M1. I'll dig for your posts then...
      08-26-2014, 02:35 PM   #17
vastano
Drives: F15 X5
PM me your email, ill just send them
      08-26-2014, 02:42 PM   #18
Flying Ace
Flying Ace's Avatar
4985
no need, I was able to find it here:
http://www.m3post.com/forums/showthr...310230&page=10
thanks again! Now I need to wait 5-months for my analysis on M1
      08-26-2014, 02:51 PM   #19
vastano
Drives: F15 X5
ok, i have yet to post my latest, ill try and do that tonight
      08-26-2014, 03:48 PM   #20
s85e90
Drives: black e90
you do want to warm everything up together.
      08-26-2014, 03:57 PM   #21
Devant
Drives: '11 M3
So many things wrong here:
First, no one should decide to change their bearings off of one blackstone report. You need to have a baseline and several reports to formulate a trend analysis and see how the engine is faring.
Second Motul 0w-30? Where did you get that this oil was okay to use, especially with new bearings? You need to use a special break-in oil with zinc and then switch back to 10w-60 or M1 0w-40 (if you believe all the reports on M1)
Third why are you letting the car idle for 10 minutes. That is the single biggest contributor to worn engine internals. You are basically running the engine starved of oil. Start the car wait 30 seconds and begin driving. This will allow oil to circulate everywhere it needs to go inside the engine, especially the top of the engine.
      08-26-2014, 04:08 PM   #22
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
It is probably not a bad idea to replace the bearings as they are probably worn.
As others have mentioned, a thinner oil can reduce further wear. But it won't fix the wear that has already occurred. It's merely a band aid at this point.
It depends how preventative you want to be.
If you do replace the bearings, please take some pictures and let us know how they look when it comes out!
Auto Detailing Enthusiast!
m3post
