Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      08-08-2014, 05:39 PM   #1
Deviant
Drives: F80 M3
Tire size and options for 20x9.5 and 20x11
I've finally picked my wheels (20x9.5 and 20x11) and now need to decide on tires. I've seen some running 295/25, 305/25, 295/30 for the rears. Trying to determine the best fit w/o having that stretched look.
Also, finding it difficult to find tires in those sizes. Michelin, Pirelli and Bridgestone seem to be the higher end options all around $1600 and Hankook and Toyo's seem to be half that price.
Are these tires going to be toast in 12-15k miles anyway? Is it worth it to spend twice the money for the higher priced ones? Does it make that much of a difference?
      08-08-2014, 07:56 PM   #2
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
I recommend Michelin every time,. If you are hard on tires Hankook are also great for the price.
I personally run Michelin on all my cars.
      08-13-2014, 08:32 AM   #3
Omar@VelosDesignwerks
BimmerPost Supporting Vendor
Omar@VelosDesignwerks's Avatar
Drives: Different Ones
Michelin if possible. None of those brands are necessarily bad but it depends what you want out of the tires. IE you will not get 12-15k out of the Pirellis.. If possible I would go with the Michelin...
      08-13-2014, 08:48 AM   #4
phantome46
phantome46's Avatar
Drives: 2015 M4 Convertible - Sakhir
Looking forward to seeing the M4 on 20 inch rims
      08-13-2014, 10:05 AM   #5
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
^ yes.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      08-13-2014, 04:41 PM   #6
Deviant
Drives: F80 M3
M3 not M4 I should've specified.
Where can I find the tire size calculator that also adjusts for different wheel widths. I've found the comparison calculators but I'd like to find the one I saw someone posted on here somewhere where it shows the wheel width and offset and you can pick different tire sizes.
f80post
