07-04-2014, 09:05 PM | #1 |
Rep 556
wheel stud install question
The damn front wheel keeps spinning when I try to torque the stud.
What is the proper way to keep the hub from spinning around other than having someone hold the brake pedal? THanks! |
07-07-2014, 10:54 AM | #5 |
Automobilist
395
Rep 2,632
I actually just threaded the studs hand tight then held one of the studs to keep the hub from spinning as I torqued them. Turner recomends torquing to 16ft lbs so yeah you don't need much torque at all.
07-15-2014, 12:45 PM | #6 | |
Rep 1,479
Drives: 2017 F80 M3
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
08-12-2014, 06:02 AM | #8 |
Rep 126
Not sure if this is a bad idea, but depending on the type of studs you are installing, you may be able to do it without taking the wheel off or jacking the car up.
Just replace one wheel bolt with a stud at at time. You should be able to just take a wheel bolt out and stick a wheel stud in it's place. If you're studs have the hex hole in the end of it, you can tighten them up with an allen key. |
08-12-2014, 12:46 PM | #9 |
Rep 12,309
Hell no. The most I've seen is 30ft-lbs, but most recommend 16ft-lbs.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-13-2014, 01:45 PM | #10 |
Rep 1,629
