BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
BPM
      07-03-2014, 01:19 PM   #1
bimdo
bimdo's Avatar
Drives: 2008 e90 m3
Oil Level Funkiness
About 2000 miles after an oil change,the add 1 qt. message came on. I check it pretty regularly,and had seen it full after the change,and gradually going down over time.I added 1/2 qt. which the mechanic had given me,left over from the oil change. Three days and very few miles later,the add 1 qt. message came on again right before i got home,so i decided to wait until the next day and not add any more.Today the add 1 qt. warning is gone,and the oil reads full on the electronic "dipstick" (using the term loosely since i ,like many others,would much prefer the real thing.)
Any suggestions,anyone else encounter this?
      07-03-2014, 01:21 PM   #2
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
Are you checking it and topping it off consistently each time? That is, are you doing it under the same conditions? (i.e. after the same type of drive, level surface, engine at the right temp, etc)
Is this the first time you've seen it consume that quantity of oil that fast? Did you check for leaks under the car/bellypan?
Past: 2011.5 M3 sedan ZCP
      07-03-2014, 01:29 PM   #3
bimdo
bimdo's Avatar
Drives: 2008 e90 m3
i have not checked it under consistent conditions. i have had to add a quart after 2500 miles before.
      07-03-2014, 01:30 PM   #4
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I had this happen recently, the indicator showing low, then the next day, full, back and forth for a couple of weeks. Changing out the oil sensor solved the issue, and the oil was 2 ticks below max and it hasn't moved since, so I would have overfilled if I heeded the first warning to add a quart.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      07-03-2014, 03:21 PM   #5
Dannys M3
Dannys M3's Avatar
Drives: Jaguar F Type R
2008 M3  [10.00]
Did you change it out or did you have it done? Just curious how difficult this is.
      07-03-2014, 03:24 PM   #6
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
It's simple. I ordered the gasket, but the actual sensor kit came with a new gasket anyway. #6 here, it's just at the bottom of the pan. Note: looks like a new part after 8/10, who knows why.
      07-05-2014, 10:11 AM   #7
S65 Underdog
Drives: a functional car.
Best of luck with this OP and thanks for the post. I was wondering what the sensor on the bottom of my pan was. Seems like a easy replace when doing your next oil change.
m3post
