06-20-2014, 10:40 PM | #1 |
Large Member
295
Rep 979
Drives: '19 Porsche C2S Cab_M3 DCT ZCP
1,200 mile service.
A friend has found a cherry 2012 M3 ZCP DCT with just over 4,000 miles on it and is asking me for advice. The issue is that the Hollywood type who leased it didn't pull the 1200 mile oil change until 2,900 miles. My amigo already knows that BMW will not issue an extended warranty because of this; my question is, "How important is this really?" What kind of damage could have occurred to the engine by leaving the break-in oil in until 2,900 miles? On other high performance cars like the 335is, the first oil change is at 15,000 miles.
06-20-2014, 11:08 PM | #2 |
Rep 837
I didn't know the 335is is even considered a high performance car???? But to answer your question... that 1200 mi oil change is extremely important! And it is more than just an oil change. If I recall, it is noted in the owner's manual and is mandatory to sustain the warranty.
06-21-2014, 12:20 AM | #4 |
Rep 4,488
To give a little perspective, ALL BMWs used to have 1200-mile service, but when Ultimate Service was introduced and BMW started looking for ways to make it less expensive to offer, the universal 1200-mile service was one of the first casualties. Somehow the M cars were spared, probably due to outcry from the engineers.
Still, the fact that BMW limits warranty coverage on such cars should tell you how important it is. BMW knows these cars are more likely to fail, and they don't want to be stuck footing the bill. And even if this will be a short-term ownership, a late 1200-mile service will hurt resale badly. I'd look elsewhere. Failing to change the driveline oils early means all of the extra metal that accumulates in those oils during the break-in period stays in there a lot longer than it should. But asking why the M3 can't be serviced like the 335is is backwards. If anything, the 335is should still be serviced like the M3 -- and that would almost certainly still be BMW's recommendation today if they hadn't started including "free" service. It's also worth noting that BMW's decreased service levels have apparently bit them somewhat, judging by the fact that they recently dropped the oil change interval to 10K for newer cars without changing the cars themselves. You can probably read between the lines there. I'd also check your facts about the warranty. I don't think the extended warranty would be voided since those are third party products -- even "BMW's", which is just an Assurant warranty. That car's FACTORY warranty may have been voided for any issues that could plausibly have been caused by a late 1200-mile service.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-21-2014, 12:30 AM | #5 | |
Rep 4,488
06-21-2014, 12:41 AM | #6 | |
Large Member
295
Rep 979
06-21-2014, 02:03 AM | #7 |
Large Member
295
Rep 979
I'm having a really hard time telling my Army mate to give up on this car - there aren't many ultra low mileage E92 M3s left.
06-21-2014, 06:04 AM | #8 |
Rep 7,110
If the price and general condirion is right I'd go for it without second thought. 2900 miles is still close to nothing, in my mind no way the extra 1700 will make a significant change on wear even if the oil would be a bit dirty. After all S65 is a high volume and quality engine which surely can't benn designed to fail over 1700m...
06-21-2014, 06:17 AM | #9 |
Rep 226
On european deliveries I have exceeded the 1200 mile service a couple of times, 2400+ or so. I have never had an issue, nor has BMW said anything. Yes, it should have been changed, but it is extremely remote that anything has or will happen with either the car or BMWNA.
Encourage your friend to get the car and enjoy it. John |
06-21-2014, 10:57 AM | #10 | |
Rep 3,482
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
06-21-2014, 11:10 AM | #11 |
Rep 256
From my 2013 M3 Manual:
Special Note – Maintenance Intervals The maintenance requirements for your vehicle are determined dynamically by the Condition Based Service (CBS) system. The maintenance items stated herein reflect the latest information available at the time of the printing of this Booklet, and are subject to change. The completion of certain subsequent maintenance items or services, as required by the BMW New Vehicle LimitedWarranty, will be specified at intervals computed by the BMW Condition Based Service system as follows: Oil Service: Engine oil should be changed with the engine at operating temperature. 1200 Mile Running-In Service The engine in your BMW M3, M5 and M6 is a race-bred engine design which includes increased power output and maximum engine speeds compared to conventional BMW 3, 5 and 6 Series engines. The increased power output also affects other major drivetrain components, such as the transmission and the rear axle differential. The 1200 Mile Running-In Service requires changing the oil in the engine, the manual transmission and the differential. The manual transmission is standard equipment in the M3, and optional in the M5. NOTE: The fluid does not need to be changed with the M-DCT Drivelogic transmission. The fluid has a long-term rating and does not need to be changed except for system repairs. The M-DCT Drivelogic transmission is optional on the M3, and standard equipment on the M5 and M6.
2013 Coupe | M-DCT | Alpine White | Fox Red | Carbon Leather Trim SOLD
Forza Michael!! |
06-21-2014, 01:04 PM | #12 |
Large Member
295
Rep 979
This situation has become as we used to say in the military, "OBE" - overcome by events.
Some guy came into the BMW dealership this morning and paid the $61k asking price for the car. Thanks for the advice, guys. |
