06-19-2014, 11:38 PM | #1 |
Rep 202
Rod Bearings Replaced
Hey everyone I recently got my rod bearings replaced almost 2 weeks ago and I would like to share my results. Car Specs:
July 2009 build date Purchased at 54,522 miles Bearings replaced at 58,768 miles Three previous owners I had no abnormal noises other than the metallic "tink" when the clutch engages (Guibo) which will be replaced soon. Car ran great with VERY little exterior and interior imperfections. I was aware of rod bearings BEFORE I purchased the car but I had the impression that it was strictly with the S85 engine. When I started reading of the rod bearing failures on the forum for the S65 I had the urge to get them replaced ASAP. It was actually quite hard for me to enjoy the car not knowing what damage was under the hood. If I bought it from the original owner I would have greater peace of mind but this wasn't the case. Better safe than sorry for a relatively inexpensive procedure. I'm grateful I went through with this as I was told this was the beginning of the end for the bearings. No damage was done to the crankshaft In order to REDUCE unnecessary damage proper warm up and ~5K mile oil changes will be adhered to. I want to say this is merely to help everyone get a better idea of if they should have theirs replaced as well. In no way do I mean to frighten anyone that their rod bearings are going to fail. Pictures: Cylinder #1 Rod Bearing (Upper) Cylinder #2 Rod Bearing (Upper) Cylinder #3 Rod Bearing (Upper) Cylinder #4 Rod Bearing (Upper) Cylinder #5 Rod Bearing (Upper) Cylinder #6 Rod Bearing (Upper) Cylinder #7 Rod Bearing (Upper) Cylinder #8 Rod Bearing (Upper) |
06-22-2014, 04:00 PM | #8 |
Stop the hate, get a V8
3850
Rep 8,625
Mikulski,
I would still recommend you get UOAs done to determine the correct oil change interval and to establish baseline/monitor trends in the long-term.
Past: 2011.5 M3 sedan ZCP |
06-23-2014, 12:48 PM | #9 | ||
Rep 202
Thought about doing an analysis of my oil when I got the bearings replaced. Slipt my mind to grab a sample though. |
06-23-2014, 01:13 PM | #10 |
ENTHUSIAST
135
Rep 2,097
Drives: 2010 Porsche Cayman
I do believe this rod bearing issue is WAY overblown but those pics DO NOT make me wish I had the car back...Thanks for posting. Only 54k miles, yikes.
"what I'm driving here...is an ending." Jeremy Clarkson
2010 Carrara White Porsche Cayman 6mt 2014 Whiteout Toyota GT-86 6mt(Sold 05/23/15) 2011 Alpine White BMW M3 6mt ZCP Coupe(forced retirement 06/06/14) 2008 Alpine White BMW 328i 6mt Coupe(retired 06/21/11) |
06-23-2014, 01:28 PM | #11 |
Rep 368
Thanks for posting your findings. It's good info.
While your rod bearings don't look great, they don't look as bad as some of the other pictures posted on this forum. I didn't know BMW offered "upgraded" bearings. Are your bearings treated?
06-23-2014, 01:36 PM | #12 |
Rep 1,097
Drives: Melbourne Red e90 M3
Thanks for posting. Agreed that these bearings don't look as bad as most posted - they aren't even really into the copper layer. I think this still proves though that this should definitely be a maintenance item - probably around 75k miles for me, assuming blackstone reports look decent.
06-23-2014, 01:41 PM | #13 |
Master Baiter
4171
Rep 634
Drives: 18 M2
I would like to know cost as well.
Do they just R&R or do they mic the crank while they are in there? Do they install the bearings on the rod and mic them as well? Thanks for sharing. |
06-26-2014, 07:14 PM | #14 |
Rep 2,301
I agree with others that the bearings don't look that bad. I would say they look like the previous owners ran 10W60, for 15K intervals. Once bearing failure is imminent, it should sound like this:
If your motor didn't sound anything like that, then those bearings could have gone 50-100K miles or more. for all we know the new bearings may go back to looking like the old ones within 15K miles, so long as you still use 10W60
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
06-27-2014, 08:57 AM | #15 | |
Rep 202
06-27-2014, 09:07 AM | #16 | |
Rep 2,301
'07 335I w/ Mods
07-26-2014, 05:28 PM | #19 |
Rep 202
I'm assuming this was to ensure proper fitment as there may have been slight imperfections on the bearings during manufacturing. By adhering to lower RPMs the crankshaft will have a greater opportunity to remove these imperfections gradually.
07-26-2014, 06:25 PM | #20 | |
Rep 1,263
I think the correct statement is to get an oil report and determine 1) if you have bad bearings 2) what is the correct oil chamge interval for your particular engine 3) ability to monitor your bearing wear |
07-26-2014, 09:55 PM | #21 |
Rep 2,224
07-27-2014, 04:11 AM | #22 |
Rep 4,381
Its worth noting that if this bearing set was sent to Clevite for analysis they would categorize the wear as perfectly normal.
Given the predominant wear pattern seen in poor condition bearings removed from S65 engines - one or two upper bearings showing copper - I suspect that the problem is nothing at all to do with the 10W60 oil but instead a function of either poor quality control of the bearings shells themselves...where some are out of thickness spec promoting high wear in those bearings while others remain perfectly normal....or some other mechanism that causes high wear in only one or two bearings. Its highly unlikely that using 10W60 can cause selectively high wear in only a couple of bearing sets. Last edited by SenorFunkyPants; 07-27-2014 at 04:35 AM.. |
