Throttle hesitation/stumbling/hunting problem at 2-4% accel pedal position
09-10-2016, 03:20 PM | #45 |
Rep 3,158
Did you code your replacement injectors?
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
09-10-2016, 03:40 PM | #47 |
Head Fry Cook at McBurgertown
507
Rep 1,005
09-10-2016, 03:42 PM | #48 |
Supreme Galactic Commander (one galaxy over...)
675
Rep 1,778
terryd5150507.00 |
09-10-2016, 04:26 PM | #49 |
Rep 3,158
Man, definitely try a new battery. Normally they should be good for 7 years or so, unless you've been doing lots of short drives or in high ambient temps.
Alternatively, put a multimeter on the battery terminals and check the voltage with the ignition on (but engine off) and at engine idle. From the Bentley manual: Ignition ON and engine OFF--fully charged voltage is approx 12.6 volts. With engine runing (charging voltage), normal voltage is approx. 14.0 volts.
--Mark Twain |
09-10-2016, 05:18 PM | #50 |
507
Rep 1,005
09-10-2016, 05:38 PM | #51 |
675
Rep 1,778
09-10-2016, 06:59 PM | #52 |
507
Rep 1,005
I agree.
I would think the alternator might be a more likely culprit for a dip in electrical current when the car's running. On the positive side, if you keep replacing parts at this rate you're going to end up with what will essentially be a brand new 2008 335i. |
09-10-2016, 07:03 PM | #53 | |
675
Rep 1,778
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
09-10-2016, 10:08 PM | #54 |
Rep 3,158
That's a good point. I assume your car had the battery cable recall work done? Also: done correctly?
--Mark Twain |
09-10-2016, 10:30 PM | #55 |
675
Rep 1,778
Yes...I never checked their work. What do I look for?
Best,
09-10-2016, 11:46 PM | #56 |
Rep 725
fwiw Andy I'm still working on mine too .
http://www.datazap.me/u/cwarren/log-...0&data=1-21-24 just encase someone has any new theories . I keep thinking a vacuum leak of some sort but cant seem to locate any issues (yet) replaced valve cover and related pcv parts before shift sector fwiw made no difference.
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
09-11-2016, 12:03 AM | #57 |
Rep 3,158
Sorry man not sure--I didn't pay too much attention to all of the uproar during the recall. I just simply had it done.
I know the circuit in question is used to monitor the battery's state, probably by observing both the voltage and current at the battery. So the recall was for cars that would stall out or not start, like the battery was dead, leads me to think the faulty monitor would effectively cause an intermittent or partial open circuit. I don't know what they did to fix it.
--Mark Twain |
09-11-2016, 12:21 AM | #58 | |
675
Rep 1,778
1. Diverter valves 2. DME chassis 3. Get factory reload of ECU from BMW 4. Replace battery 5. ??
Best,
09-11-2016, 12:21 AM | #59 |
675
Rep 1,778
That's me, too.
Best,
09-11-2016, 11:37 AM | #60 | |
507
Rep 1,005
Perhaps it's starting to go bad? https://www.ecstuning.com/BMW-E92-33...tery/ES165984/ |
09-11-2016, 11:45 AM | #61 | |
507
Rep 1,005
Perhaps they've frayed? https://www.ecstuning.com/BMW-E92-33...ery/ES2537619/ |
09-11-2016, 07:48 PM | #62 |
Rep 3,158
Honestly, between the two options I'd go with the battery.
I think the odds are better that it's just a very slowly fading battery causing brownout gremlins in the ECU and other electrics under certain conditions. Modern BMWs are (in)famous for being extremely, and I mean extremely, sensitive to the battery's condition.
--Mark Twain |
09-12-2016, 02:39 PM | #63 |
Rep 3,158
So, I just talked with my buddy who had the problem similar to OPs. I wanted to double check with him.
He stated one of the first things he noticed before things got progressively worse (over a period of a little over a year), was the engine simply wouldn't idle right. It would rev up and down, oscillating regularly like it couldn't find the right engine rpm. Over the following months, he'd start having the more (BMW-)traditional battery symptoms of starting the car and his radio settings would have been reset, etc. Eventually the battery died completely and the car wouldn't start. He replaced the battery, and the car ran perfectly again. No oscillating idle, no drivability issues, nothing. Looking back on it, he thinks the first symptoms started for him with about 5 years on the battery; it died completely at year 7.
--Mark Twain |
AndyW674.50 |
09-12-2016, 04:01 PM | #64 | |
675
Rep 1,778
Best,
09-12-2016, 04:36 PM | #65 |
Rep 232
Not battery
Having the same issue......just so happens car died about a month ago while driving. Bad alternator and battery. Had both replaced. Still have the same issue with throttle hesitation/stumbling at 2-4% (usually 3rd or 4th gear at about 2000RPM0). I really think it's the updated software that BMW installed when I got the HPFP replaced. Living with it for now.
09-12-2016, 04:55 PM | #66 | |
675
Rep 1,778
Best,
