Throttle hesitation/stumbling/hunting problem at 2-4% accel pedal position
09-02-2016, 12:10 PM | #1 |
Supreme Galactic Commander (one galaxy over...)
672
Rep 1,778
UPDATE: If you follow the whole thread you will see the problem was solved by reset of ECU to defaults. Leaving rest of original post for posterity.
Note: Starting a new thread to separate this issue from my previous CP gasket leak thread that unmasked the problem. Has been going on for ~8K miles. Car is well maintained by a CDO person -me. (CDO is like OCD but the letters are in the correct order., like they should be..) Video of behavior here: https://www.youtube.com/watch?v=wWnYEbxtnu4 This is a sequence with constant 3% accel position(but cycling throttle and RPM - see datazap of a similar run below), then idle(smooth), then rev to 2K(smooth). Datazap of behavior here: http://www.datazap.me/u/andyw/thrott...10-11-12-13-20 <- NOTE: This log is not synced with video - took log after video since same phone used for both. Summary of problem: Between ~2-4% accelerator pedal position, throttle position varies about 1-6%. Car idles fine. Above about 2K, fine. Behavior exhibits on the road as well. No codes. Frustrating problem. Have seen others post of similar issues on this forum and others so have done a LOT of research and have tried to eliminate things logically (to the tune of about $1500 or so in parts, at this point. Car has 120K so $$ not really a "loss", per se - new parts is still a refresh IMO) This problem manifests on the road in slow commuter traffic and in driving slowly around a parking lot so makes the throttle response frustratingly unpredictable and jerky sometimes. Infuriating that the last two tiny crap cars I rented on my business trips had better response at low throttle than my car! Have done the following: Replaced injectors. Replaced spark plugs Coils less than 25K old. Nearly new vacuum hoses. Replaced Boost solenoids. Replaced cam position sensors. Replaced VANOS solenoids. Replaced VANOS check valves. Walnut blasting done 30K ago. (thx, cwarren ) Replaced both TMAP sensors (upgraded CP TMAP twice - to N20 with BMS cable, then back to stock - no change) No boost leaks Replaced throttle body to charge pipe gasket o-ring(more below) Have tried multiple MHD tunes, including flashing back to stock stock. Flashed Alpina transmission mod back to stock. No effect. Smoke test reveals no leaks Even tried changing burble options in MHD as they seemed to help another forum member...didn't really help me. Car has mods but I assess they are not players. CP now ER CP(no leaks). Problem existed with previous BMS CP. DP's are now high flow catted c-PE. Problem existed with stock DP's. MHD tuned, but have flashed back to stock stock with no change in behavior. Have reset lamba/fuel/VANOS/Throttle adaptions with MHD multiple times. No effect. Did the "manual" throttle reset also. Some have said that using the ISTA/D software somehow resets differently and could solve my issue...but I haven't spent the $100 to try that yet. I guess i could poke around with INPA to see if it does the same thing. Really running out of options. Last fewI have on my list are: 1. WB O2 sensors (I have em on my workbench, but job looks like a PITA - should have done with the DP's ) - DONE - NO EFFECT 2. Buy ISTA/D and see if it somehow resets differently than MHD. - GONNA TAKE TO DEALER AND UPDATE/RESET ALL ECU's 3. DME harness (Ug) 4. DME itself ($$$) 5. Throw away car and buy a new one Problem really is small, in the sense that the car drives and pulls awesome most of the time and you can actually forget it exists...until you get in bumper-to-bumper traffic or drive around a parking lot for a while trying to find a spot. It is easier to manage in Sport mode as the revs are typically higher for a given speed/load. Anyway, any help appreciated.
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune Last edited by AndyW; 02-17-2017 at 12:42 AM.. Reason: Updated info |
09-02-2016, 07:00 PM | #3 |
672
Rep 1,778
Yeah, I read some of those. Not sure which modules tho'. I have thought of taking it to BMW to have every ECU checked and updated to the latest software...but I imagine that will cost a pretty penny!
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
09-02-2016, 07:43 PM | #4 |
Rep 2,590
SurprisinglYa it doesnt. Most updates are just simple checkmarks that the tech chooses and they let it run. May take 8 hours to run all the updates but they usually will only charge for 2 hours give or take.
09-02-2016, 08:20 PM | #6 |
672
Rep 1,778
Thx. Guess I'll ask my SA for a quote. Can't hurt!
Best,
09-02-2016, 08:21 PM | #7 |
672
Rep 1,778
Nope. not that I can tell from visual observation or logs.
Best,
09-02-2016, 09:59 PM | #8 |
Rep 8
I'm sorta on a thread over in the e90 section that is exactly on this topic (http://www.e90post.com/forums/showthread.php?t=483381). Unfortunately, no solid solutions over there either.
I've had many of the same things changed out that you list, and it still happens. Just replaced the "rear" DV with a new one (stock version), and the symptoms got a bit better, but have not completely gone away. So, given you've upgraded your DVs, I am thinking that while mine might have been bad (and somehow making it worse), it was not the source of the problem. Search continues :-( |
AndyW672.00 |
09-02-2016, 10:05 PM | #9 | |
672
Rep 1,778
Thx for linking the other thread! Last edited by AndyW; 09-03-2016 at 07:25 AM.. Reason: More info |
09-02-2016, 11:53 PM | #10 |
Rep 3,158
Vacuum leak. Maybe somewhere near your vacuum booster?
Wait, I guess someone else mentioned it already.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
09-03-2016, 06:35 AM | #11 |
672
Rep 1,778
No vacuum leak. Still have vacuum if I pull a connector 30 min after turning engine off. I also replaced all vac lines about 25k ago. I would also suspect a vac leak would cause issues at idle? The lack of an issue at idle really complicates this!
09-03-2016, 10:57 AM | #12 |
Rep 3,158
I hear that. Is your idle speed normal? 650-700 rpm?
Sometimes an engine computer will see a rough(er) idle and correspondingly up the idle speed a bit.
--Mark Twain |
09-03-2016, 10:58 AM | #13 |
Rep 3,158
Also, I note that you messed around the throttle body--what about the throttle position sensor? If it gets dirty it could send...."sticky" signals to the DME on small throttle changes.
--Mark Twain |
09-03-2016, 12:26 PM | #14 |
672
Rep 1,778
09-03-2016, 12:29 PM | #15 |
672
Rep 1,778
Where is the sensor? The TB has been removed a couple of times for walnut blasting and such. I don't remember a separate sensor. Others have replaced the TB for this symptom with no luck so I stopped going that direction.
09-03-2016, 05:02 PM | #16 |
Rep 3,158
I believe it is bolted right onto the side of the throttle body. Comes as a one-piece unit (sensor unit + throttle body).
I note that your data logs show TPS readings...
--Mark Twain Last edited by galahad05; 09-03-2016 at 05:07 PM.. |
09-03-2016, 05:19 PM | #17 |
672
Rep 1,778
09-03-2016, 06:07 PM | #18 |
Rep 3,158
I wonder if you could clean it instead.
EDIT: Understand this series of TPS is potentiometer based. That is, as the throttle is moved, the voltage reading various smoothly with the changes in position. At least the voltage is supposed to vary smoothly. This can get messed up with dirty contacts, though, for example. They mess up the voltage measured by the computer. If there's a problem internal to the potentiometer, well that's a whole 'nother problem. Just a possibility.
--Mark Twain |
09-03-2016, 08:12 PM | #19 |
672
Rep 1,778
$275 and I have to leave it for a day. If the O2 sensors don't work I guess it can't hurt.
Best,
09-05-2016, 07:22 AM | #20 |
Rep 143
I had similar issue with throttle hunting and jerky acceleration on low pedal input with my primary O2 bank 2 dead. Replaced it last weekend and now all back to normal.
09-05-2016, 09:12 AM | #21 |
672
Rep 1,778
terryd5150507.00 |
09-05-2016, 12:26 PM | #22 |
Rep 143
