Throttle hesitation/stumbling/hunting problem at 2-4% accel pedal position
09-05-2016, 02:04 PM | #23 |
Supreme Galactic Commander (one galaxy over...)
675
Rep 1,778
09-05-2016, 03:35 PM | #25 |
675
Rep 1,778
Thx Martial. I actually went down that path a few months back, including a transmission flash back to stock and adaptation relearn process. Then I realized it will do it in Park in the garage holding the throttle at 2-4%. Transmission can't affect the engine in Park, can it? Maybe that's a bad assumption?
09-05-2016, 05:02 PM | #26 |
Rep 574
Looks like a vacuum leak to me. And checking vacuum at the canister doesn't mean anything that's tied to the vacuum pump. When was your last walnut blasting and did the symptoms come about around that time? Those O rings are nice failure points. Also the nipple for the line to the DV's is prone to damage during blasts when the manifold is removed.
09-05-2016, 05:43 PM | #27 | |
675
Rep 1,778
09-05-2016, 06:08 PM | #28 | |
Rep 574
09-05-2016, 06:16 PM | #29 |
675
Rep 1,778
Just replaced both WB O2 sensors (as in today - and I double checked the connections). Car seems smoother and symptoms didn't appear on a short drive but I can cause the oscillation in the driveway. Seems smaller, tho'. Guess it can't hurt to do another vacuum test.
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
09-05-2016, 06:18 PM | #30 |
675
Rep 1,778
Appreciate everyone throwing out ideas...it helps me relook at stuff in a different way!
Best,
09-05-2016, 06:52 PM | #32 |
675
Rep 1,778
You are a mind-reader...I was just about to ask what that reset did!
Best,
lightmanek116.50 |
09-06-2016, 08:11 PM | #34 |
675
Rep 1,778
O2 sensors definitely did not fix it.
lightmanek116.50 |
09-08-2016, 03:38 PM | #35 |
Rep 66
Drives: 2008 335i E92 6MT
Garage List 2014 BMW 535D Msport [0.00]
2011 BMW 335D [0.00] 2008 Porsche 997TT [0.00] 2011 335i E93 [0.00] 2008 335i E92 [0.00] 2008 750i [0.00] |
I hope you can get this figured out. I have the same issue with mine.
08 6mt FBO. It really got bad after installing the VRSF exhaust a few months ago. Can not stand to use the cruise, the surging is too bad at highway speeds. I have tried all the normal software stuff with JB4, MHD, resetting adaptations, etc... no help. If I had not just installed m3 suspension bits and Ohlins coilovers I would get rid of it.. |
09-08-2016, 11:31 PM | #36 |
Rep 3,158
Noticed any excessive oil consumption? PCV valve....
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
09-09-2016, 02:45 AM | #37 |
675
Rep 1,778
09-09-2016, 11:57 PM | #38 |
Rep 3,158
Okay (still reaching for straws here). Have you tried different gas? What octane?
--Mark Twain |
09-10-2016, 12:54 AM | #39 |
Rep 3,158
So I broke out my Bendley on the 3 series, to see if I can throw some info in here, in case it can give someone ideas to explore.
It says: 3 Series turbo engine utilizes a calculated air mass system. This calculation makes use of the following signals: - VANOS setting (load acquisition) - Throttle setting - Intake air temperature (air density correction) - Engine temperature (air density correction) - Engine speed (cylinder charge) - Intake manifold pressure (throttle correction) - Ambient pressure (air density, altitude correction) The calculated air mass is adjusted with the oxygen sensor signal (mixture ratio) and injector timing and corrected if necessary. In addition, this is what it says about the N54's throttle assembly: <installation of throttle assembly> --Installation is reverse of removal. --Reattach throttle assembly connector with care. CAUTION--it is possible to twist the connector before plugging it in. This can cause damage to the harness and connector. --...
--Mark Twain |
09-10-2016, 12:57 AM | #40 |
Rep 3,158
Also, how old is your battery? A buddy of mine with an '08 was getting pissed off at his car because it was having ever increasing drivability issues, with no codes thrown. Started off with uneven power at light throttle.....
Ended up being a slowly fading battery. He replaced it a couple months back, car runs perfect now. He's back in love with his car.
--Mark Twain |
09-10-2016, 06:50 AM | #41 |
Rep 66
The Battery is a good idea.
I know mine is coming up on 5 yeays old. Not sure about OP, but I will try that for sure. Thanks! |
09-10-2016, 10:09 AM | #43 |
Rep 3,158
Here's one hypothetical scenario: pretty much every signal from the analog sensors in the car, like the throttle butterfly and the accelerator pedal, have to be converted to digital numbers in the ECU. Pretty much all analog to digital converters rely on a reference voltage to compare against. If that reference voltage were out of spec just a little bit.....
--Mark Twain |
09-10-2016, 02:11 PM | #44 |
675
Rep 1,778
For reference, here's a log with MHD 7.1 stg 2+ 91 Oct.
http://www.datazap.me/u/andyw/mhd-71...10-11-12-13-24 Doesn't appear to have a boost leak. Only cylinder 4 has minor corrections. Fuel pressure OK. Only thing I noticed this time is that bank 1 lambda lags bank 2 slightly on throttle-off. Indicates over fueling not excess air. So injector leaking? Would be surprised, as I have replaced all Injectors and while they were used, I tested all of them. Not sure if this would cause my issue, either. Any thoughts on how much difference in lambda recovery is too much? In the meantime, I'll check spark plugs for signs of a leaky injector. Last time I checked, they were all dry. |
