08-28-2019, 11:34 AM | #89 |
Rep 381
Posts Drives: '21 330i xDrive Join Date: Dec 2009
08-28-2019, 12:08 PM | #90 |
Rep 1,923
Turkish Pickle3084.00 |
08-28-2019, 12:51 PM | #91 | |
Rep 139
FuzzyPeaches490.50 TXSTYLE14028.00 |
08-28-2019, 03:04 PM | #92 |
Rep 2,250
I remember my first try with a SR and I cut myself to pieces. A friend told me that I shouldn't be applying any pressure, and letting the weight of the razor do all the work.
Never really mastered it. I currently use a conditioning oil before, lather with brush, and now disposables. But that's only if I haven't shaved in a few days. If it's been longer than 3 days, I have to start with my Wahls unit first to get as close as possible. Otherwise I would burn through the disposables like crazy.
TXSTYLE14028.00 |
08-29-2019, 02:10 AM | #93 |
Schmollbraten
12516
Rep 1,985
That had never worked for me, just the weight pressure from the razor.
I got few spots at my cheeks which are slightly backspringing and w/o pressure the hairs won't got cut as its meant to be. Also, when your skin gets older the tension slips away and I have to stretch some areas to achieve a plain shavearea. All those commercials where young models are just pulling the razor over their face are bollox and beyond of practics. To be honest, your mentioned razor model had made me curious to experience that for myself. On the flipside, I wear almost every day white collars and the risk to scratch myself and make a bloody mess seems to be not the lowest….hmmm….what to do?
08-29-2019, 11:41 AM | #94 | |
Rep 9,160
As for nicks, a styptic pen, or alum block stops the blood quickly. An aftershave, balm or light lotion is a good follow up. |
08-29-2019, 12:52 PM | #96 | ||
Rep 155
08-29-2019, 03:12 PM | #98 |
Rep 2,250
I always keep a stypic pen around!
08-29-2019, 04:45 PM | #99 |
Rep 1,965
Girls can also give birth, that's not something I'm willing to try either. They think (and say) they are tougher than us.....I say let them think just that. I've learned not to argue with them.
Turkish Pickle3084.00 Maynard3861.50 |
08-29-2019, 05:54 PM | #100 |
18174
Rep 9,389
08-29-2019, 07:41 PM | #101 |
Rep 139
Successfully performed my first DE shave today with the same setup as above but added Noxema as a preshave and Thayer's witch hazel as an aftershave. Did 3 passes ... with the grain, cross grajn and against the grain. No cuts or irritations. Got to do better on the area directly beneath the nose. Used a cheap Omega boars hair brush ... it does stink but told the smell will go away in a week or two.
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
08-29-2019, 08:59 PM | #102 |
drunk poster
6614
Rep 3,649
08-29-2019, 09:32 PM | #103 | |
Rep 139
You know that’s a perfect description of the smell! Made me laugh. Last edited by dougt.ah3; 08-29-2019 at 09:45 PM.. |
08-29-2019, 09:42 PM | #104 |
Rep 2,272
been using a Merkur razor and Feather blades for almost 10 years.
Would never use those shitty cartridges razors again.....hard to believe so many suckers use them. the Razor industry is a total scam because double edged razors are infinitely better and more cost effective in every way.
don't read this. too late...
08-29-2019, 09:44 PM | #105 | |
Rep 2,272
don't do 3 passes and don't go against the grain or across the grain. just 1 pass. with the grain.
08-29-2019, 09:50 PM | #106 |
Rep 139
^ maybe when I develop a better technique. It’s my first time and the 3 passes were necessary. Will work on it.
Always had to go against grain with cartridges so it is ingrained for now. Last edited by dougt.ah3; 08-29-2019 at 09:56 PM.. |
08-30-2019, 02:36 AM | #107 |
Schmollbraten
12516
Rep 1,985
Rumor said that you have also a taste for a tared and feathered a**, so you*re out and banned
08-30-2019, 09:05 AM | #108 | |
Rep 10,394
Boar can initially have an odor but it will eventually dissipate. I use a badger brush.
"Drive more, worry less. "
08-30-2019, 01:19 PM | #109 | |
"Salud"
14028
Rep 4,691
Posts Drives: F01 & F15 / Mineral White Join Date: May 2013
While we are on the subject, I want to share with you something I have learned the hard way regarding greys in my eyebrows... Sooner or later you WILL get GREYS all over: Head, chest, back, nose, face, balls and yes even eyebrows! I started getting a couple here and there in the exact same spot. Very noticeable to me but my wife didn't mind nor complain. Well in my genius attempt to reduce the unfavorable appearances of these white threads growing from my brows, I decided to start plucking them. Initially no issues. I would keep removing the rogue strands whenever they grew back. But after a couple of years, I noticed that I was getting small patches there. Now fortunately, my brows and lashes have been longer than average. So I am able to hide these bare spots by the length of other brow strands. But what happened exactly? I turned to a Dermatologist who explained that the follicles of hair that turn grey are "weakened" normally by the loss of pigmentation: thickness, color, oils, etc. But she says this is especially true of the eyes! By plucking them repeatedly from the same location, it literally stop producing ANY hair growth. So that's my testimony for the day/years. Remember it and don't make the same mistake as I. |
08-30-2019, 02:20 PM | #110 |
Rep 96
Maybe I will die poor compared to what you guys might be spending, but this thing has lasted me... Jesus it must be 10 years at LEAST?
They still sell the cartridges at Costco and I replace my blade maybe once every 2 months? I tried the Gillette Fusion and later models but they went too far. This model is perfect and the vibration really does make it an easier shave. (Yeah yeah dildo jokes are coming ) |
