BMW 3-Series (E90 E92) Forum
Does anyone know...
01-07-2015, 11:29 AM | #1 |
Rep 3,312
Does anyone know...
...what would happen if I put my JB4 onto my 335i that is already running an Evolve map????
Until I get the evolve map removed I was wondering the consequences (or more what would the JB4 mapping do) when the initial values are not the standard ones but the evolve mapped settings? Thanks, Raj.
E92 335i / M3 Hybrid - The Build
01-07-2015, 11:36 AM | #2 |
Rep 2,692
I don't know.
Part of my thinks because the jb4 reads and assess and then tunes accordingly especially in map 5 that it will be fine. The other part thinks that as its not starting from standard it won't be good. I'd just wait if I were you just to be safe. |
01-07-2015, 11:40 AM | #3 | |
Rep 3,312
I've spoken to Evolve about removing the map but they turned round and said they probably don't have the original file (thought they all keep them tbh) and want £100 to remap it back to stock. So I'm trying to find another alternative to get it back to stock so I can add my JB4.
01-07-2015, 12:49 PM | #4 |
Rep 9,097
I had a similar scenario.
335i with encrypted map. Guy has JB4, so jb4 on the top of map. He stated that he used to get engine light on heavy acceleration (if I remember correctly). Since map was encrypted, nobody was able to remove it and he did not know who remapped the car (was done by previous owner). He brought his car to me. Tried to flash it in standard way but bmw equipment could not read the engine module. Bit of fiddling and flashed it to standard map. All good and he was happy. His next goal was to do back end flash and when he tried to do that, engine was still encrypted. So with bmw equipment we managed to put the car back to stock but encryption stayed there!
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
01-07-2015, 01:46 PM | #5 | ||
Rep 2,796
If they have say AutoLogic software will be available via the menu to 2013/14 spec which may well have a benifit as I've discovered on quite a few cars we've had in with issues. Charge wise they charge what we charge for a software update. To answer your cars file pre re map we hold everything on a hard drive(tagged by reg and chassis)so if we have issues we can return to pre remap without drama and haven't had an issue since undertaking our free standing re map issue re switching between std and re map nad visa versa if the car needds to be returned to OEM without trace.. But can't speak obviosuly for another companythough I will say on the F series it will be spotted even if you think you are smart enough to remove it (again all too complicated to explain here) Quote:
Its a complicated subject TBH. |
01-07-2015, 02:33 PM | #9 |
Rep 2,796
Put it this way you explain it I'll answer it and if I don't know ill ask, we can do everything in house re map wise including cloning ECU's(if your ECU is corrupted by having an ECU from another vehicle that spec wise is 100% compatable from a donor vehicle)we can do a "Dolly the Sheep"to the donor ECU without any drama's.
01-07-2015, 03:04 PM | #11 | |
Rep 3,312
Ideal solution is to remove remap (so back to stock) then put JB4 on. But in meantime wondering if can just put JB4 on even though remap is still there.
01-07-2015, 03:22 PM | #12 | |
Rep 2,796
I've seen a good few 335i owners with the JB4 installed, (which always has to be deactivated before we work on their cars) through our doors to know that it offers great VFM & options which you can't ignore compared with a straight out of the bid re map they offer so much and in my expierience seem to perform if performance is the right word more strongly, in execution though not so sure. Hence for me I'm sticking with the re map on my car(though our tuning partners have both had JB4's in and examined how they go about setting out their stall in terms of the file dataand that I'm awaiting their info with interest) |
01-07-2015, 04:09 PM | #13 |
Rep 1,846
Your already advancing timing, leaning out afr and upping boost a jb4 will effectively piggyback and add on to the above not a good idea esp likely you could cause knock etc, I wouldn't do it no chance.
01-07-2015, 04:19 PM | #14 |
Rep 2,796
Spot on hence the conflict, I didn't actually get to see the end result of the guy who came to us, but he was surprised, JB4 wise v re map for those who are interested the JB4's seem to me to feel more 'savage' can't knock the VFM, and the things you can do with this great bit of kit, but the execution for me isn't the greatest.
01-07-2015, 04:56 PM | #15 |
Rep 3,312
Tbh boys this is why I've held off fitting it as my first thoughts are its not the right way to go due to the possible conflicts or over stressed mailings with piggy backing. I was just wondering if anyone had come across this tbh.
01-08-2015, 07:26 AM | #16 |
Rep 278
SUB"D . Can you do the remapping remotely via internet connection?
(JB4 stage 2, in my garage)Now CoBB V3 , VRSF 3.5" Stainless Steal catless DP, 7" VRSF FMIC with upgraded lower CP.
