E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Alignment makes a difference
Reply
      09-17-2012, 10:15 PM   #1
gunnerxq
gunnerxq's Avatar
Drives: e90 "325i"
I was starting to get worried that I would have major repair bills coming up on my car such as bushings and control arms. The reason being is at highway speeds the car would float around and would need constant correction to stay straight.
During normal and spirited driving the steering felt like on my sisters passat because it was so light. So I go get an alignment and ask for the sport package one. the mechanic goes to the computer and tells me there is also msport or m package alignment, so of course I get it right away.
Well Now the car doesn't float, it doesn't matter what speed im going and can actually drive in a straight line. The steering is back to BMW like standards. And actually feels a little heavier then stock. The speed at which tire squeal begins on turns is quite a bit higher now also.
So guys get your alignments, it was definitely $98 well spent. And don't forget to ask for the different alignments if you don't mind a little more tire wear.
Can anyone explain how an alignment can make such a difference such as making the steering stiffer?
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
      09-17-2012, 10:27 PM   #2
tsensational
Drives: 328i Coupe
In some cases, you're getting more tire to the ground than pre-alignment. A bit more friction means a bit stiffer.
      09-17-2012, 11:31 PM   #3
osukf09
Drives: 2011 e92 M3 ZCP
I've had a similar experience. Definitely a much heavier steering feel to the left and right after a good alignment (car was pulling slightly right prior).
      09-18-2012, 12:25 AM   #4
2ndname
Autobot
2ndname's Avatar
Drives: E90 325i Auto~NO~Go
2006 BMW 325i  [10.00]
Agree. I myself would recommend an alignment once a year, even without any mods being done to the car.
      09-18-2012, 01:07 AM   #5
marshall834
marshall834's Avatar
Drives: 2021 BMW M2 Comp
I've never heard of different "types" of alignments. Interesting. Was this at the dealer?
Past:
2015 A3
E90 335i
E46 323ci
B6 Audi S4
      09-18-2012, 01:41 AM   #6
chazzz
chazzz's Avatar
116
Drives: 2018 Chrysler 300S
$98 alignment at BMW dealer? That's a good deal. Would love to get my car aligned by BMW dealer at that price.
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic.
      09-18-2012, 01:53 AM   #7
lbernielu
Drives: 2006 330i, sp, Bilstein, H&R
It is valuable to research the different types of alignments possible, particularly with respect to toe settings for the front wheels. Factory numbers tend to have moderate toe in, which increases stability, makes turn in more diffucult, and increases tire wear. M car settings may specify less toe in, and many experienced drives prefer 0 toe or slight toe in for the front. Front camber settings are also a matter of taste, with some drivers sticking to stock and others going up to two degrees negative or more.
      09-18-2012, 10:51 AM   #8
LocDawgg
Drives: AW e90
My buddy works at Toyota, and he aligned my car using regular settings then he aligned it using the m-sport settings. It felt much better afterwards. The computer and software he uses as options such as sport package, Msport, lowered, etc.
      09-18-2012, 11:11 AM   #9
Thp4
Thp4's Avatar
Drives: 2011 335i msport
Is the "sport" alignment different from the "msport"? I would think they would be same as msport is just sport with different bumpers / trim. I didn't think there was any suspension difference.
      09-18-2012, 11:22 AM   #10
dhanni848
Drives: 06 330i
Going to get my car aligned this week. I have the sport package on mine and the steering is quite stiff. Does the Msport just alter the camber to put more tire on the ground? Would this actually allow the tires to wear more evenly?
      09-18-2012, 11:30 AM   #11
ndog14
Drives: E90 328xi 6MT
$98 for an alignment at a dealer? My dealer quoted my friend's mother $600! Hah!
      09-18-2012, 12:27 PM   #12
gunnerxq
gunnerxq's Avatar
Drives: e90 "325i"
Nope it wasn't at a dealer. They put in my car model and year and 3 different options came up on the computer.
      09-18-2012, 01:16 PM   #13
Bamaben
Bamaben's Avatar
183
Drives: 07 335i blk/blk/alum 6MT
You can only change toe on front so if steering feels different it is because you have more toe-in which causes more feathering but a better tracking feel. Different setups are for different amount of toe front and back and different camber in back
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey
mods: blackout grill, finishing rods, badges, Blacklines.
      09-18-2012, 01:16 PM   #14
nycbr
Drives: 2008 TiAg 328xi
where did you get the alignment?
      09-18-2012, 02:28 PM   #15
BlackedOutF30
F30TUNER
BlackedOutF30's Avatar
Drives: BSM 2014 335i Sportline
2014 BMW 335i  [10.00]
Well from what I have read I believe non-NA m-sport actually comes with a type of v1 perf. suspension. So I would imagine that could be the difference?
      09-18-2012, 10:21 PM   #16
gunnerxq
gunnerxq's Avatar
Drives: e90 "325i"
"Guys tire buys"
373 Veterans Road West Staten Island, NY 10309
(718) 317-8473
      09-18-2012, 10:33 PM   #17
gunnerxq
gunnerxq's Avatar
Drives: e90 "325i"
Why do I have no feathering now then compared to before the alignment with a stiffer feel?
Reply
e90post
