BMW 3-Series (E90 E92) Forum
O2 Sensor Removal N52
11-27-2010, 06:51 AM | #1 |
Rep 3,415
Now that the Bentley repair manual is out, it seems a bit pointless to write DIYs for repairs, since they are covered in the manual. But I have found that most repair manuals leave out the little details for the various procedures they cover, which are the things you really want to know anyway. With that in mind I decided to share a remove and replace DIY for one of the E90 N52 O2 sensors.
This DIY is for the Bank 2 Sensor 1 (the harder of the two up-stream sensors to replace). The good news here is once you get to it, it screws out of the manifold quite easily (good job BMW for using anti-seize at the factory and good exhaust manifold material - stainless steel), the bad news is getting to it. This DIY is long, so I've made it as a MS Word file so it can be printed. As usual I didn't take any pictures (it takes too long to complete the job), but the DIY is descriptive enough that you really don't need any. |
09-06-2012, 04:52 PM | #2 |
Rep 40
ENINTY ---
Great write-up! Thanks for posting. I'm getting ready to tackle the B1 S1 sensor in my 07 Wagon. Would you say B1 S1 is much easier to get to and complete the job? BTW --- $55 for the O2 sensor, Genuine BMW part --- what a deal!!! Now, the part sells for $140+ (Bosch) and $200+ (Genuine BMW). JC |
09-06-2012, 08:35 PM | #3 | |
Rep 18,829
09-06-2012, 10:28 PM | #4 |
Rep 473
and $55 is for a Universal 4-Wire Oxygen Sensor
not a oem plug and play
09-07-2012, 12:23 AM | #5 | |
Rep 40
So, when you removed the B1S1 sensor, did you have to remove anything that had to do with steering rack or tie rod? My Bentley manual said 'remove the right tie rod from the steering rack' Also, was removal of the sensor fairly straightforward --- or did you really have to work at it or use the big breaker bar? I bought an off-set type sensor socket --- is that what you use? Thanks in advance EFT! |
09-07-2012, 12:24 AM | #6 |
Rep 40
09-07-2012, 05:00 AM | #7 | |
Rep 18,829
I did my sensor just after the time Eninty posted the DIY and the price for the OEM sensor (B2 S1) was $55 from Tischer. |
09-07-2012, 11:19 AM | #8 | |
Rep 40
Thanks EFT.
I'm certain about B1S1. I looked under the hood this AM. You are correct --- it is clearly visible and reachable w/o removing the engine plastic cover. However, to remove the O2 sensor wire plug/harness, it appears to be further towards the rear of the engine. I could not see where the wires ended. So, looks like I need to remove the engine cover. Quote:
09-07-2012, 09:28 PM | #9 | |
Rep 18,829
06-06-2013, 05:52 AM | #11 | |
Rep 18,829
You can use a 7/8ths box wrench on the sensor if you can fit one on it, but you have to cut the cable off; the connector does not fit through the wrench opening. I don't think a 7/8 deep socket will fit over the O2 sensor even with the cable completely removed. The special sockets are not that expensive and every auto parts store will have the correct sized socket. Last edited by Efthreeoh; 06-06-2013 at 06:03 AM.. |
