11-18-2020, 11:31 PM | #8 |
Rep 2,758
12-15-2020, 12:03 AM | #10 |
Curve Thrasher
625
Rep 3,773
I really want one of those setups.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
12-19-2020, 12:43 PM | #11 |
Rep 262
Soo jealous, sweet setup
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
02-19-2021, 08:35 AM | #14 |
Rep 621
I'm a bit surprised to not see more people either use VR in addition to or completely swap out their monitor setup for it. It adds a whole other level of realism. Just being able to look through corners like you would in real life is such a difference.
02-23-2021, 05:27 PM | #16 | ||
Rep 304
I have a triple monitor setup that is curved and the visibility is great. On iRacing it seems that more members use the monitors than VR. The three monitors are actually more expensive as well, plus stand, etc, so it's certainly not an economic decision. 🤔 But to each their own. |
WhoU421.00 |
08-26-2021, 10:53 AM | #18 |
Rep 3,009
Nice!
Martin Logan haven't seen that name in forever. I really like how you tie wrapped the monitor brick to the rig, I'm going to steal that idea and tie wrap mine to the monitor arm and get it off the floor. I would have expected the power strip to be completely filled w/plugs |
09-03-2021, 11:13 PM | #21 | |
Rep 294
Posts Drives: 2019 M240i Coupe RWD Join Date: Feb 2019
Also when I drive, I take advantage of my peripheral vision, which VR still has a ways to go. Yes, you can turn your head, but in real life I'd never turn my head as much as is required with VR. |
10-12-2021, 05:58 AM | #22 |
Rep 6
Loving the soundsystem!!
///M Power-Belgium64708.50 |
