Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      05-06-2015, 01:04 AM   #1
Bimmer Caravan
Bimmer Caravan Of NYC
Bimmer Caravan's Avatar
Drives: 01-530, 02-M5
2001 530I oil issue?
I seem to be adding oil frequently. about 2 to 3 qts between oil changes....
It is my daily driver.. it's a manual.
I've changed the vanos line, engine cover gasket, & oil filter housing....
I got an oil change a week ago today 5/6 and I had to add a qt of oil yesterday....
Any thoughts.....?
      05-30-2015, 08:00 AM   #2
GJR
GJR's Avatar
Drives: 2003 530i
I just asked my mechanic about this on my 2003 530i manual transmission. He said it is most likely the "CCV," or oil separator. He says it requires removal of the intake to get to it, and he would charge $500 to fix it. Common issue, unfortunately. Search online for "BMW CCV" and you'll see what I mean. Good luck.
      06-01-2015, 02:55 PM   #3
Bimmer Caravan
I did that.....
The M54 is know to eat oil
      06-18-2015, 12:04 AM   #4
Bali
E46 Fanatic
Bali's Avatar
Drives: E46 E84 F15
Originally Posted by GJR View Post
...it requires removal of the intake to get to it...
No need to remove the intake manifold to replace the CCV and related hoses. I have done the M54 CCV many times, mostly on E46's which have less space than E39's, and never had to remove the IM.
You do need to remove the air box, MAF, intake boots, throttle body, idle control valve, and a few other peripherals. It helps tremendously to also remove the oil filter housing and air distribution manifold as you gain valuable space to access the CCV and connected hoses. It is not a difficult job, but does take several hours due to the number of parts that have to be removed.
I usually do all these at the same time "while I'm in there" for the CCV.
OFHG
VANOS oil line
CCV valve and 4 hoses
All vacuum lines
Air distribution manifold o-rings
Dipstick o-rings
Dipstick tube o-ring
Upper and lower intake boots
Clean ICV and TB
DISA o-ring
TB gasket
      07-03-2015, 06:52 PM   #5
j1gilles
j1gilles's Avatar
Drives: 2009 335xi
Just did a CCV for a friend today. I took the intake off because I wanted to replace the gaskets at the same time. Taking the intake off makes it easier to replace all of the vacuum lines.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
Tags
oil, oil indicator
