Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      02-05-2015, 01:25 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
821
Drives: Independent Tuning Specialists
:: ECS Tuning :: Introducing ECS 74.1mm Hub Adapters/Spacers
For the E39 generation 5 Series, BMW curiously chose to utilize a high-offset, 74.1mm centerbore wheel arrangement.
The decision has unfortunately limited the options for E39 owners hoping to fit BMW wheels with the more popular 72.6mm centerbore to their vehicle.
The simplest, safest, and most effective solution comes from ECS in the form of lightweight aluminum, black-anodized Hub Adapters and Wheel Spacers.
13mm to 20mm conventional spacers are offered to adapt your wheels to the common 72.6mm centerbore, while bolt-on hub adapters are available in 25mm and 30mm sizes.
Click HERE for your E39 13mm Hub Adapter Kit with extended lug bolts
Click HERE for your E39 15mm Hub Adapter Kit with extended lug bolts
Click HERE for your E39 18mm Hub Adapter Kit with extended lug bolts
Click HERE for your E39 20mm Hub Adapter Kit with extended lug bolts
Click HERE for your E39 25mm Bolt-on Hub Adapter Kit
Click HERE for your E39 30mm Bolt-on Hub Adapter Kit
      02-10-2015, 04:29 PM   #2
ECSTuning
ECSTuning's Avatar
821
      06-02-2015, 12:49 PM   #3
ECSTuning
ECSTuning's Avatar
821
      08-23-2017, 11:32 AM   #4
ECSTuning
ECSTuning's Avatar
821
Click HERE for your BMW E39 M5 (2000-2003) Hub Adapters
Click HERE for your BMW E39 540i (1997-2003) Hub Adapters
Click HERE for your BMW E39 525/528/530i (1997-2003) Hub Adapters
