05-15-2014, 03:24 PM | #1 |
***** noob
1366
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Has anyone actually look at the wheels offset (those that took delivery)??
Seems like this info is top secret still *Edit* stock M235 specs (thanks to 2blue4you) 7,5JX18 ET:45 8JX18 ET:52
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-15-2014, 04:01 PM | #2 |
Rep 4,128
Drives: M235i & G30 540i
Yeh I'd like to know the 19" wheel offsets also
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
05-15-2014, 04:30 PM | #3 |
Rep 229
These are 19" accessory wheels
Offsets are the same for 18" and 19" ET45 front, ET52 rear Doesn't seem like you can do too much width wise with the car. I got some 8.5s in the back now, and it doesn't look like you can go a whole lot wider without something rubbing. |
05-15-2014, 06:20 PM | #4 | |
Rep 4,128
05-15-2014, 07:23 PM | #6 | |
Rep 4,128
hatuey0.00 |
05-15-2014, 07:41 PM | #7 | |
Rep 229
http://www.tirerack.com/wheels/resul...rSpecial=false But only 245 width tires on those. A 265 tire should fit on that rim, but it might be that the wider tire will rub something. I know there is not a whole lot of fender clearance with my 245 tire on 18x8.5 rims. |
05-15-2014, 08:20 PM | #8 |
Rep 926
rears are 52.... don't remember the front. I spent all week at the wheel shop trying to figure out what 19" wheels will fit the car without having to purchase a 2 or 3 piece wheel.
The high offset made the selection pretty slim. I was told that if I want any type of concave or deep lip I'd have to go fully custom 2 or 3 piece. I'll post the exact specs tomorrow. |
05-15-2014, 08:21 PM | #9 |
***** noob
1366
Rep 10,479
52 rear...thats some pain in the balls offset
2006 325xi (Sold)
05-15-2014, 08:54 PM | #11 |
Rep 408
pics please??
'14 M235i(current)ED
'11 E93 M3(past)ED '08 E90 328i(past)Local |
05-16-2014, 12:35 PM | #15 |
Rep 319
05-16-2014, 12:36 PM | #16 | |
***** noob
1366
Rep 10,479
Will add on top for others to see
2006 325xi (Sold)
05-16-2014, 05:27 PM | #18 |
Rep 246
Thinking of putting factory 245's on front and running 255's Michelin Pilot Sport's on back with factory 7.5" & 8.0" wheels. What does everyone think?
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
05-18-2014, 02:17 AM | #19 |
Rep 319
08-11-2018, 10:33 AM | #20 |
Rep 55
M235i Offset
Can you do a 18x9.5 ET35 without any rub? I haven't seen this as a setup in all around. I've seen the 18x9.5 in the tears but not the front. I've been told it won't work
Or does it have to 18x8.5 all the way around? I have x drive so I don't want a staggered setup. Want to be squared up. Was looking to do this.... |
03-06-2023, 02:32 PM | #21 |
Rep 8
Can someone confirm it this would fit on my M235i?
8J ET30 on all 4 corners, 19" wheels. Stock tire dimensions (225/35R19 and 245/30R19) lowered on ST XA coilovers. Thank you in advance. |
