05-13-2014, 12:41 AM | #1 |
Rep 150
launch control
hey does anyone know exactly how to do the launch control, which mode does it have to be in? just traction off or DSC off or sport+
2014 M235i Mineral Grey, JB4, ER DP, BMS Intake EWG Beta test, 35% e85,injen intake stage 3 fuel pump by fuel it
05-13-2014, 03:23 AM | #2 |
Rep 926
funny topic. if you're auto i would say dsc off and track off for best launch.
i have an MT and noticed when i revved my car once to hear the exhaust, the rev would hold at 4k on sport+. going to look into it a bit more |
05-13-2014, 01:12 PM | #3 |
Rep 166
Check out this video for info about launch control:
1st off, your car has to have travelled 6 miles prior to initiating LC. Additionally, you have to have your steering wheel straight, if it is not straight or you move after you start this sequence, LC will not initiate. Here are the steps: 1) depress brake pedal FULLY 2) Press the traction button once 3) put car into D, then press to the left to go in Sport tranny 4) Push throttle pedal past the resistance point on the floorboard. 5) brings revs to 2k Launch control active should light on your dash, release the brakes and you are off. Last edited by SoCal235; 05-13-2014 at 01:19 PM.. |
05-13-2014, 01:34 PM | #4 |
Rep 150
Aweesome thank you!
05-13-2014, 01:56 PM | #5 |
Rep 926
how about on a manual? has anyone noticed the rev hold around 3-4k rpm?
not sure if its a launch feature but it would hold the rev on a complete stop. |
07-14-2014, 05:15 PM | #6 |
Rep 350
Drives: 2014 BSM/CR M235i
Pretty awesome. Can't wait to try this out.
07-14-2014, 05:22 PM | #7 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
really... the MT can do its own launch control?? if it's holding the rev for you while at a complete stop, that'd be the launch control feature.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
07-14-2014, 05:24 PM | #8 | |
Rep 5,262
auto also keeps rev under 3-4 k.... it's a safety feature so you don't blow up the engine |
07-14-2014, 06:55 PM | #11 |
What goes here?
450
Rep 1,356
alright, yeah.. so I confirmed it will hold the rev's at 3K in any mode on the MT... whether that could be considered launch control or not.. IDK. But I did get a few firm launches 'testing' this
2019 G30 M550i
07-14-2014, 08:19 PM | #12 | |
Rep 926
i havent don't it since that one time i encountered it, but how did you get it to activate? i can rev my car over 3k from complete stop now :-\ |
07-14-2014, 08:34 PM | #14 |
Rep 1,053
The most pathetic thing about this whole launch control is that you are basically guessing at when the car can do it. If you haven't driven 6 miles, it won't work. If you have the wheel turned, it won't work. If the car is too hot and you have driven a lot, it won't work.
The least they could have done is given you a menu item showing when the car is ready to perform that task if you ask it to. Because of all this guessing, to me the launch control on this car is mostly a gimmick. It's sad because it's a feature I was quite excited about early on. |
07-14-2014, 08:48 PM | #16 |
Rep 926
if youve seen the previous posts the revs will hold around 3.5k. After more digging there are people in f30 that get good launches from it as well.. if you can get off the line wouldn't that pretty much be same as launch control?
07-14-2014, 08:54 PM | #17 |
Rep 5,262
no, cause the only thing it does it's hold the revs till you release the clutch, as soon as you drop the clutch there is no control anymore and you can be spinning the tires at 7k rpm
the one in the auto, will "clutch" in/out several times per second without cutting power if there excessive wheel spin.... think it like an opposite of ABS but for the clutch if it makes any sense |
07-14-2014, 10:40 PM | #18 | |
Rep 926
07-14-2014, 11:06 PM | #19 |
What goes here?
450
Rep 1,356
The few test launches i did with this "feature" today in Sport+, I got some pretty good launches with no wheel spin whatsoever. They weren't complete clutch drops but close enough. I'm actually kind of satisfied with it!
07-15-2014, 12:26 AM | #20 |
Rep 350
I really can't wait to try this out. Been looking forward to it for some time now.
07-15-2014, 01:10 AM | #21 | |
Rep 926
also i noticed if you pump the gas again after it holds at 3.5k it'll go up to 4 sorry, this is a really bad example but it should give you an idea. i was going uphill granny shifting so dont mind that hehe Last edited by kerm1t; 07-15-2014 at 01:26 AM.. |
