E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Need suggestions: 3 Injectors not Working
      05-09-2014, 11:29 PM   #1
Focus
Drives: N/A
Hi all,
So my car has had a crazy issue where it vibrates violently after a hard run one day. As of now, apparently 3 of the injectors aren't " Getting Power " or firing. I'm being told to replace the ECU as it's not supplying power to those three injectors but that just doesn't make sense to me. What would you guys reccomend I ask to have done. I dont think going big and replacing a whole ECU could be the problem as i've never read that in any thread i've searched.
      05-09-2014, 11:32 PM   #2
Focus
Drives: N/A
Just for clarification it's cyclinders 4, 5 ,6
      05-10-2014, 02:04 AM   #3
Andrewah05
Andrewah05's Avatar
Drives: 335i TiAg
Who told you to replace the ECU
      05-10-2014, 08:53 AM   #4
N3m3sis
Drives: 335i
Is it just a misfire for those three cylinders? And other codes along with them if so?
If you turn it off then start it again does it run ok, or just get codes?
      05-10-2014, 09:58 AM   #5
caliguy562
Drives: E92 335i
Codes associated with the misfire? Ecu replacement or fix required if you have the ecu internal failure code. Do you drive an '07 335i? Ecu failure is pretty common with msd80.
      05-10-2014, 03:37 PM   #6
Morpheus
Drives: 335i Titanium Silver
http://www.e90post.com/forums/showth...pair+fried+dme
      05-10-2014, 05:37 PM   #7
Focus
Drives: N/A
Originally Posted by Morpheus View Post
Noticed this thread last night and brought it to my shop this morning. Tested the mosfets. low and behold, cylinder 4, 5 ,6 are bad on the ECU. Ordered the mosfets and will be replacing and updating the thread once i get them
      05-15-2014, 08:37 PM   #8
Morpheus
Great! Best wishes.
      05-15-2014, 11:02 PM   #9
bigtigga01
Drives: 07 335i
1988 BMW 325is  [0.00]
2011 BMW 550i  [0.00]
2014 BMW X5  [0.00]
2007 BMW 335i  [0.00]
Just did this last month. It will fix your issue and you will save $$$$.
Sandlapper BMWCCA #481069
07 e90 6AT, Cobb V3 protuned by Motiv, Aquamist HFS-4, DCI, ER CP/Tial BOV, AA DPs, AA Sport Intercooler, 19" BBS CH-R, Pure Stage 2 Turbos
      05-16-2014, 08:46 AM   #10
Jklad
Jklad's Avatar
Drives: 2007 335i Coupe
Good luck, i got hosed by BMW on this issue.
2007 E92 335i MT
      05-16-2014, 12:05 PM   #11
Focus
Drives: N/A
all fixed. look here http://www.e90post.com/forums/showthread.php?t=986168
e90post
