E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Can someone tell me whats going on here....
      05-09-2014, 07:28 PM   #1
vr4spd
Drives: E93 335is Sapphire Black
I went to install my DCI today. Noticed a significant leak. anyone have any ideas how to fix it?
Thats oil all over the bottom of my air box...fml
      05-09-2014, 09:01 PM   #2
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
Oil Filter Gasket more than likely.
      05-09-2014, 09:19 PM   #3
vr4spd
seriously hope your right
      05-09-2014, 09:22 PM   #4
stashtrey
Drives: 08 E90 335xi TiAg
Highly likely OFHG.
      05-09-2014, 09:25 PM   #5
N0Chill 335i
Look next to the oil filter cap, if there is oil build up in that little triangle indentation then that's definitely your problem. Also check your coolant. When I had my leak, oil got into the coolant housing too because they're so close together.
      05-09-2014, 11:58 PM   #6
vr4spd
I will check this in the morning thanks!
      05-10-2014, 08:47 PM   #7
vr4spd
Took some pics of the Oil filler cap. Some residue, however there is none on the valve cover. How would it make its way all the way to the charge pipe?
      05-10-2014, 08:59 PM   #8
N0Chill 335i
No, not there. The oil FILTER cap. It's the big black circle that's on top of the steel looking square. If you are standing in front of your car looking at the engine, there is a small triangle shaped indentation to the right side of that steel square closest to you.
      05-10-2014, 09:02 PM   #9
N0Chill 335i
In the picture the oil usually builds up in the area I circled if it's the oil filter gasket.
      05-10-2014, 09:50 PM   #10
vr4spd
Copy that, thanks.
      05-11-2014, 06:21 PM   #11
vr4spd
So there is very little reside in that area. When I took off the stock air box oil literally was pooled, ran down the side and dripped off. also noticed it in another area. See attached pic
to me it seems like to is leaking where the charge pipe is connected to what Im guessing is the throttle body idk.
      05-11-2014, 06:32 PM   #12
Young_Man
Young_Man's Avatar
42
Drives: E90 335i
2nd pic is the power steering reservoir. You should be able to just replace the o-ring to fix that problem. http://www.realoem.com/bmw/showparts...41&hg=32&fg=20
As far as the other leak goes, I'm guessing it's the oil filter gasket.
AA Signature Exhaust / AA 3" Catless Downpipes / VRSF 7" FMIC / AFE Dual Cone Intake / ER Charge Pipe / Tial Q BOV / RPI Scoops / RB Upgraded PCV & Cap / BMS OCC / Alpina Trans Flash / Powered by JB4 G5 ISO
      05-11-2014, 06:37 PM   #13
Ingeniator
Ingeniator's Avatar
Drives: 07 335XI(90) 09 135I(82)
Looking at your first pics. A boost leak is possible at the throttle body/charge pipe joint. It could also be cracked a little. If it was a significant amount of oil it could be because your PCV is not functioning correctly or your seals may be going on the turbos.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
      05-11-2014, 08:07 PM   #14
vr4spd
Thats what I'm afraid of, this isn't my first turbo car. Oil outside of the engine isn't a good thing ever. I'm going to detail the engine bay this week and see if it reappears. As far as the oil filter gasket there wasn't really any residue outside the housing...
e90post
