Please help!!!!!
05-09-2014, 11:59 AM | #1 |
Rep 295
Please help!!!!!
Hey guys, I have an 08 135i with 68,577 miles on it.
Mods: Rb Turbos (since 64,838) Spec stage 2+ smfw (64,838) Vrsf dp's and 7inch Er cp with hks Afe dci Problem: misfire cyl 1 What I have done to try and fix it: From 65k I replaced the Bosch plugs (don't know the gap) Walnut blast, 3 new injectors (bank1),All new coils. Walbro 255 inline booster, brand new hpfp. Both fuel pressures are excellent. LPFP sensor. Ngk's yesterday, gapped at .22 When I drive under heavy load there is a clicking noise. I can accelerate through 2nd no problem and it's fast as hell. But say I put it in 4th going 35 and try to build boost (heavy load) and there a clicking noise. If it doesn't misfire. The misfires have been haunting me for months. I have everything I have into the car and don't want to get rid of it. Please help I am in desperate need. |
05-09-2014, 12:06 PM | #3 | |
Rep 295
05-09-2014, 12:10 PM | #4 |
2095
Rep 43,350
Can you post a log for us? What are you using to tune the car?
I wouldn't recommend going WOT in 4th gear @ 35 MPH, you're putting a lot of unnecessary strain the engine and your clutch. |
05-09-2014, 12:14 PM | #5 | |
Rep 295
05-09-2014, 12:21 PM | #6 |
Rep 606
05-09-2014, 12:46 PM | #7 |
Rep 1,525
misfire
05-09-2014, 01:30 PM | #8 |
Rep 295
I need something as far left field as possible. He has known it's not anything anyone has been saying for months. On n54tech or anywhere. He's talked to wedge, terry, rob at Cobb. Everyone that knows anything, he's talked to.
05-10-2014, 11:51 AM | #10 |
Rep 1,290
05-10-2014, 11:54 AM | #12 |
Rep 295
05-10-2014, 12:09 PM | #14 |
Rep 1,093
run a leakdown on it. If it isn't fuel or spark it should help you narrow down the problem.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
05-10-2014, 12:32 PM | #15 | |
Rep 295
05-10-2014, 01:07 PM | #17 | |
Rep 719
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
05-11-2014, 01:41 PM | #19 |
Rep 1,093
Leak down. If you don't want to play swap that part just run the diagnostics. You already said you've pretty much ruled out fuel and spark. That leaves compression leaks or coolant/oil ingestion. A properly performed leak down test will tell you where to start looking.
05-13-2014, 08:12 PM | #21 |
Rep 1,093
Compression check and leak down are two different things. Also what do they consider good compression. How much experience does this shop have with tuned cars. Turbo cars and misfires are nothing new.
05-17-2014, 12:55 AM | #22 |
Rep 295
Idk the compression numbers but I know it's fine. And the leakdown didn't get them anywhere. So supposedly Dave will be pulling the cams Monday. He said nothing looked suspect under the valve cover. The is getting out of hand.
