335Xi fitment
05-06-2014, 02:46 PM | #1 |
Rep 55
335Xi fitment
I just picked up some style 95s and was wondering if they'll fit with the tires they came with. I have an 07 335Xi on stock suspension.
Front - 19x9 et24 245/45/19 Rear - 19x10 et24 245/45/19 |
05-06-2014, 05:49 PM | #2 |
Rep 1,188
Drives: 2008 e92 335xi
I would not use those tires. They are a lot taller than stock and your speedo will be off by almost 10%.
05-07-2014, 09:47 AM | #3 |
Rep 342
Drives: E90 Monaco Blue 335i xdrive
I wouldn't use 45 on a 19". Should be 35 I think and if staggered then 35 front and 30 rear.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
05-07-2014, 01:58 PM | #4 |
Rep 55
Thanks for the replies. So they'll definitely rub?
What would be the ideal width/sidewall height for my setup? And what's the acceptable range in case I can't find the ideal size because I'll most likely be buying used. |
05-07-2014, 03:10 PM | #5 |
Rep 1,188
I would go with 235/35/19 front and 265 (or 275) /30/19.
05-07-2014, 05:29 PM | #6 |
Rep 101
Drives: 2009 335i x-drive
You'll rub for sure. I have 19X9.5 et 33 with 275/30 and get slight rubbing.
05-07-2014, 05:54 PM | #7 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
05-07-2014, 07:37 PM | #8 |
Rep 1,464
Drives: 2009 BMW 335xi
Those wheels should fit with narrow tires of the 235/265 variety although you may have problems in the front and will need a fender roll in the rear. To be safe you could go 225/35 fronts and 255/30 rears.
05-08-2014, 08:36 AM | #9 |
Mr. Monaco
155
Rep 4,197
since you're on stock suspension you shouldn't have much of an issue. I went with a little stretch when I ran 95s. 225/35 and 255/30 toyo
05-13-2014, 03:05 PM | #10 |
Rep 167
Oh that's nice
Alpine White|Coral|e92
ZSP|ZCW|ZPP|X-Drive |
05-17-2014, 07:52 AM | #12 |
A family of bimmers
2748
Rep 7,742
you are going to lower the car right? if not, stock height and those wheels will look funny with a stretched tire and huge wheel well gap
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
05-20-2014, 08:49 AM | #13 |
Rep 55
Wasn't planning on it. Which springs would be a good match with 235/35/19 and 275(265)/30/19? Just enough to cover the gap, I can't go too low since the roads here suck.
