E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Refresh under the hood/tune up
      05-06-2014, 09:42 AM   #1
Jed
IN THE KNOW!!!!!!!
Jed's Avatar
Drives: 1994 E36 325is; 2007 E92 335i
Hey everyone,
Currently own a 2007 335i with ~131K miles. Original owner. All stock right now.
No issues but going to freshen everything up for the hell of it. On the short list, I'm going to replace the valve gasket, new RB PCV and hose and add a BMS catch can as well as new spark plugs (overdue) and I figure new coils since I'm changing the plugs and I'll be removing them anyway.
Aside from the hoses and aforementioned parts, anything else to consider like maybe new diverter valve and VANOS solenoid?
What hoses should be on the list for replacement and OEM or do you guys have recos for aftermarket (like Samco or whatever?).
Thanks!
Edit: Just some things that already have been replaced or done:
New waterpump (failed 2 years ago)
Carbon buildup cleaning
New injectors (recall)
HPFP (recall even though I didn't have an issue)
2007 Jet Black 335i Coupe: Saddle Brown interior | ZSP | ZCP | ZPP | iPod integration.
1994 Hellrot 325is: Sport Package | PSS9 Coilover | AutoThority chip | AutoThority CF Intake | UUC pullies | Dinan HiFlo Throttle Body | UUC StrutBarbarian | UUC Evo II SSK | BMW Motorsports X Brace | Rogue Engineering DMS exhaust | Kumho Ecsta V700 R Comps |
      05-06-2014, 10:48 AM   #2
MDORPHN
Drives: AW 1M
I'd also replace all the vacuum lines in and around the manifold.
Neil
      05-06-2014, 10:49 AM   #3
tc535i
Drives: 2007 335i, 2001 330i, 1995 M3
I'd do drivetrain fluids too (tranny/diff)
      05-06-2014, 10:50 AM   #4
Jed
IN THE KNOW!!!!!!!
Jed's Avatar
Neil
Neil!!! What's up man??? I forgot you have the 1M! RICH!
Any recommendations on hoses or just OEM?
      05-06-2014, 10:54 AM   #5
Jed
IN THE KNOW!!!!!!!
Jed's Avatar
Hey tc535i,
Good idea, I've seen Mr. 5 using Royal Purple for his diff and tranny. I've used Redline in my 325 but I figure that Royal Purple is good stuff as well.
Thanks!
      05-06-2014, 11:08 AM   #6
MDORPHN
Drives: AW 1M
Hey Jed -
Any decent quality silicone hose will do. Some threads on this or the other N54 forum about this.
Neil
      05-06-2014, 11:18 AM   #7
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
I'd run a pressure test and see if boost leaks calling for any replacements (FMIC mounts/ CP, DVs any of these could have leaks from xconns) - vaccum solenoids and actuator get shot too (bulb like things that feed the actuator sitting ontop of exhaust manifold) - If you're stock it might be ok .. definitely Trans Filter ($96 from Amazon) and Fluid (Castrol, ZF, Purple, redline whatever u like), rear differential fluid (30 min DIY), Trans mounts (1 hr DIY by Rob Beck), look for leaks underneath, sometimes oil filter housing leaks, and then at that mileage check CV joints bootcover, turbos if u wanna tune it later.... also I'd run 0w-40 at that mileage (no 0w-30) ...I've done almost all of these mods myself so u can do it too (except cvj & turbos)
      05-06-2014, 11:06 PM   #8
peter91118
peter91118's Avatar
29
Drives: '01 325xit, '09 335i
Save the cash and clean your vanos solenoids rather than buying new ones
e90post
