E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Codes came up after dp install
      05-05-2014, 05:01 PM   #1
jeison33
jeison33's Avatar
Drives: e90 335i sedan
Put the vsrf dp on . Now car gives me check engine light,I checked the codes via obd2 scanner and the following codes came up 0420 and 0430 and the same time. I checked to make sure pre cat sensors were in correctly. Car has 83k . Should I replace both front sensors or is there any way to find out which sensors need to be replaced. Current mods are fbo. Thanks in advance
      05-05-2014, 05:37 PM   #2
Myrder
Myrder's Avatar
Drives: 2010 E92 335i MSport 6MT LMB
When you installed catless DPs, unless you are on auto-clear or have a DP Fix you will get those codes. Did they come up after you drove the car for around 40-60miles?
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56|
-I will look on your treasures, gypsy. Is this understood?-
      05-06-2014, 04:10 AM   #3
jeison33
jeison33's Avatar
I have a jb4 g5 . Car runs on map 5 and codes come up once a day. On the jb4 does this dp fix have to be enable? Or since I switched to map 5 does it automatically switch to auto clear?
      05-06-2014, 07:30 AM   #4
335NJ
Drives: 2008 335i 6MT E90
The DP Fix is an actual part, seperate from the JB4. Which is unavailable at the time.
Confirm you have Auto-Clear on, to do this, make sure you are set to
Speedo 1--Tach 3
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
      05-06-2014, 08:20 AM   #5
v1nc86
Drives: 335xi
Speedo 1--Tach 3
DP Fix is a separate part for those who are not running the JB4 iso. But it's a built-in feature in the JB4 and it's set to auto-clear by default... so you should be fine! But check just in case...
YouTube | 335xi Best 1/4 mile: 12.3@110 MPH | 335xi Top speed: 0-270 kph (165+ mph)
      05-06-2014, 08:36 AM   #6
Eat.Sleep.Race
Out Boosting...
Drives: F30 335i M-Sport
yupppp
Alpine White M-Sport F30
      05-06-2014, 05:10 PM   #7
335NJ
Correct, but if I want to go pass emissions at the inspection station, I need a DP Fix. Even with the JB4 ISO, all that does is clear the codes, which is really all the OP was asking, but I wanted to clear up the terminology a bit.
The DP Fix wire harness essentially mimics the o2 as being there receiving proper input, and the I/M Monitors will show ready. The JB4 ISO will not bring the I/M to readiness, which in turn, will bring up a code as the o2's are confused per se.
      05-06-2014, 05:16 PM   #8
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Back in the day BMS labeled the JB4 as having a DP-FIX but it was meant to portray that you would not throw a check engine light for installed downpipes.
They also sell a separate "DP FIX" which refers to a unit that can be used to clear the check engine light for those that don't have a tune or for those that want the ability to set readiness codes for emissions purposes. Although they function similarly the stand alone dp fix has more features as it can be used to set the readiness codes needed for inspection purposes.
This terminology has been omitted from the current JB4 description for obvious reasons as it tampers with emissions, which is also why the stand alone dp fix is no longer available by them.
      05-06-2014, 05:34 PM   #9
335NJ
Thank you for confirming
      05-06-2014, 07:09 PM   #10
chepy24
chepy24's Avatar
30
Drives: 2009 alpine white 335i xdrive
so what are the codes you are supposed to get? i got p0036 p0056 p2c9e and p2c9f i know one of my post cat o2 sensors is done for have the new one laying around ready for install just wondering about what codes im supposed to get i have the ses light on too but assuming its cuz of the o2 sensor but may be wrong lol thanks in advance
      05-06-2014, 10:11 PM   #11
pnastyFL
Drives: ..
so if i put on downpipes how do i clear the code without auto clear. auto clear seems sketchy because if something serious were to happen you wouldn't get a code
      05-07-2014, 03:58 AM   #12
jeison33
jeison33's Avatar
Ok thanks . I'll check the auto clear menu.
      05-07-2014, 07:48 AM   #13
shadow191
Drives: 2017 Volvo XC90 R-Design
I forget the details, but if there is something seriously wrong, auto-clear won't immediately clear it. Your CEL will come on.
You don't clear the code without auto-clear unless you run the stand alone DP Fix but some say that has it's own problems as eventually one of your banks can run lean since the DP Fix is modifying the signal.
      05-07-2014, 07:51 AM   #14
jeison33
jeison33's Avatar
Oh ok maybe terry can provided some knowledge .
      05-07-2014, 12:06 PM   #15
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
The only way is to clear with auto code clear. The auto clear will still flash the CEL if something more serious happens.
Mike
      05-07-2014, 05:58 PM   #16
V8bait
Drives: e92 335i 6mt
I don't know why I bother anymore. This has been answered 9999999999999999999999999999999999999999999999999 times.
1) Install backend flash of your choice with BT cable.
2) Enjoy no more codes without having to use autoclear, so you can still get codes for other things when they inevitably break.
3) Enjoy passing emissions as long as your car is still in an overall good state of health/running clean/etc.*
*= most laws allow for one monitor to not be in a "ready" state and still pass. This also assumes your car is capable of passing for numbers and passes the visual inspection (secondary cats in place, how comprehensive they are etc). YMMV. If your specific area requires all monitors to be "ready" or you have a leaking gas cap, EVAP system etc you will require a DPFix or to fix the other problems on the car first so that only the cat readiness is missing, if the visual check/tech is very comprehensive and looks under the skid plate you will require re-installation of primary cats.
All information provided is theoretical based on others experiences. I drive a Prius.
/thread.
      05-09-2014, 10:53 AM   #17
Jhe
JHE
Drives: 2010 335i Coupe
Auto Clear
Auto clear, is made to clear aftermarket performance mods... Example, cat-less downpipes. You will still get check engine lights if there is something else wrong... Example, I had a bad O2 sensor (with cat-less DP's) and my check engine light came on with auto clear enabled. The other option is to connect your car to your computer and you can check for DME codes manually. Go to the user adjustment page, there is a drop down with a list of the firmware versions for whatever car you have, make sure that is set to the correct version for your car and click on the "Read DME Codes". It will display any codes, if there is something not right. If a code comes up, email it to BMS and they will help diagnose the problem.
e90post
