E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > OEM vs Walbro 255 vs 455 flow rates.....hmmmm
      05-05-2014, 11:24 AM   #1
07tundra
Drives: 8.1L Chevy 2500hd
Just in case some folks have not seen this or have forgotten about it. Terry did some very good testing here. Which I believe is awesome knowledge to have especially with Vargas coming out with his HPFP upgrade
      05-05-2014, 11:34 AM   #2
135Pats
135Pats's Avatar
Drives: A few BMWs
455 flows very well, no doubt about that.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      05-06-2014, 09:08 PM   #3
07tundra
It sure does and a good price I might add.......lol
      05-08-2014, 11:15 AM   #4
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
What exactly are we looking at here? Are values in "Test 1" and "Test 2" columns flow rates? Which row shows the data for the 455?
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      05-08-2014, 11:41 AM   #5
C.Pop
Drives: 335i
It's the 450 guys, not the 455.
      05-08-2014, 05:01 PM   #6
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
You're mistaken, it's the 1000.
      05-08-2014, 05:34 PM   #7
SteveAZ
Drives: 135i Cab
Technically, it's a Walbro F90000267 and Walbro refers to it as their "450lph" pump.
If you search for it on ebay and plug in 455 you'll come up with bubkis....but if you search for a Walbro 450....you'll get all kinds of listings because that is how Walbro refer's to it.
Basically at some point somebody advertised it as a "455" because at 30psi under the right conditions it flows pretty close to that. You'll never get that in our cars.
In addition when all these upgrades started people were confusing the Walbro 450 and Walbro 255....
All pretty trivial really because unless you have other fuel system upgrades...both will max out your HPFP anyways.
2008 E88--Fuel-It! Stage 4 LPFP & PI--PS2 turbos--JB4/MHD--FBO--662whp/604wtq
2011 E90--Fuel-It! S2BL LPFP and PI--PS2 Turbo--JB4/MHD--FBO--546whp/589wtq
2013 Mini JCW--Tune--DP--FMIC--a couple Fuel-It! goodies--265whp/320wtq
2013 F10--JB4/BM3
2015 F82--Fuel-It! Stage 3 LPFP & PI--PS2 Turbos-- JB4/BM3-FBO
      05-09-2014, 02:22 AM   #8
07tundra
Absolutely some were confusing the 450 and the 255. Also confusing the fact that although the Walbro 255 does very well in e85 it is not "technically" an e85 pump and the 450 Walbro is.
      05-09-2014, 04:35 AM   #9
SteveAZ
Drives: 135i Cab
The factory pump isn't "technically" and E85 pump either....
2013 F10--JB4/BM3
      05-09-2014, 12:40 PM   #10
07tundra
You are correct Sir so then alot of folks have a two non e85 compatible pumps in their tank, thanks for pointing that out. But being that the 450 or 455 is inline it compliments the oem pump when it struggles with e85. As does the 255 but in that later scenario you have 2 non e85 pumps complimenting each other. But hey whatever works!
      05-09-2014, 04:40 PM   #11
07tundra
flow
Look at row 6 column LPH that specific setup outflows any current solution offered.
      05-09-2014, 04:52 PM   #12
C.Pop
Drives: 335i
Have you considered attaching multiple 450's in series? Of course with the factory bucket.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
      05-09-2014, 07:28 PM   #13
07tundra
You'd have to wire it up in a different way. The way it's currently setup a stock 20 amp fuse is all that's needed
e90post
