E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Beware Wedge flash is deceiving
      05-04-2014, 07:59 PM   #1
xtrackdog
Drives: 2008 335i
Mated to the Alpina transmission flash, it is so smooth and refined in D that I was wondering where the power was.
Well I just got back from a run on a deserted stretch of country road.......and there was the power. Pushed me back in my seat getting to 100, and still had more to give.
To desribe this version, I say, smooth, refined and deceptively powerful. Best of both worlds.
This is my 2nd flash from Wedge, first was powerful, a little edgey, still smooth but this version is smoother and more refined. It's great for the excutive type who want the refinement of a BMW luxury car, but the power that can take on any muscle car. My car is a sleeper.
Thanks Ken.
Btw the alpina flash in D holds 6th for so long that on a long slight grade, my car with ppk felt like it was working hard. This flash solves that problem
      05-04-2014, 11:07 PM   #2
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I just got a update and running a very aggressive map 6 with custom boost setting. Car is a little insane lol! Smooth as can be, but turns into a monster.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      05-05-2014, 08:42 AM   #3
WedgePerformance
BimmerPost Supporting Vendor
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
      05-05-2014, 09:05 AM   #4
Raptor04
Drives: 335xi
Is this updated flash for 100% gas or e85 blend or are there updates for both?
335xi
      05-05-2014, 10:12 AM   #5
Iceberg3232
Drives: 2008 335xi Coupe
Rob - care to share the settings for Map 6?? Been messing around myself.
335 XI Coupe/ RB Turbos/ JB4 w/ Wedge Backend / Meth / Inline LPFP / E85 / UUC SSK / Spec2+ SMFW / HPF 7'' IC / Forged DV's / AR DP's / BMS DCI / Apex Arc-8 /Hankook Ventus V12 EVO / KWV1 / HPF Exhaust/ NGK/
      05-05-2014, 10:46 AM   #6
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
I see what you did here...
      05-05-2014, 12:11 PM   #7
Infamy
underground
Infamy's Avatar
63
Drives: alpine white 335 E92
2010 BMW 335i  [9.66]
what are you crazy thats like asking him to sleep with his wife
      05-05-2014, 12:13 PM   #8
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
In the log above are these: 1st column is what I had and what the log above is at, 2nd column are what I am using now (unbelievable) & 3rd column is what I will go to if I turn it down slightly. Don't see myself doing that. Remember this is very aggressive and your car should be running perfectly and have done lots of logging to make sure everything is fine.
      05-05-2014, 12:15 PM   #9
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Lol! I posted them...I guess he can sleep with my wife!
      05-05-2014, 12:22 PM   #10
Infamy
underground
Infamy's Avatar
63
lol
      05-05-2014, 02:28 PM   #11
Iceberg3232
Rob's the man!
Wish I had more runs on the dyno I woulda messed around with Map 6.
      05-05-2014, 02:31 PM   #12
tc535i
Drives: 2007 335i, 2001 330i, 1995 M3
Rob's the man!
Can a solid map 6 be made from a few good logs?
      05-05-2014, 02:32 PM   #13
Iceberg3232
My feelings are when tweaking within such a narrow range here - everything will be car specific. Some like the high boost and silly timing (Rob and my car included) and some don't!
      05-05-2014, 02:34 PM   #14
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I started much lower and logged and logged to make sure timing was prefect. Ran the first column all winter. I then turned it up and logged and logged and it seems solid.
      05-05-2014, 02:35 PM   #15
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
this is very true, I have seen some cars that don't like it above 13*
e90post
