Suspension Bottoming Out
05-04-2014, 01:41 PM | #1 |
Rep 60
I have the stock xi suspension with 18s and rft tires. The suspension bottoms out with a loud 'bang' all the time even with fairly small potholes.
I was going to go to konis with zsp springs but I'm afraid the bottoming out will only get worse. Does anyone know if the konis will help the bottoming out? Are the konis shorter than the stock shock? |
05-04-2014, 02:06 PM | #2 |
Curmudgeon and Pedant
690
Rep 3,489
I doubt it's "bottoming out". What you're experiencing is probably the first reactions to the stiffness of the RFT sidewalls. Google "pothole explosion" for some amusing threads on this phenomenon.
You can do several things: avoid potholes, get used to it, go to 17" rims with more sidewall, or (many people advocate this) change to go-flat tires. Personally, my go-flat winter wheels/tires are just as bad as my RFT sport package wheels/tires. |
05-04-2014, 02:24 PM | #3 | |
Rep 124
Drives: s2000
̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶s̶1̶4̶ >F20C->1̶.̶8̶t̶-> n54
05-04-2014, 07:55 PM | #4 |
Rep 701
You're not bottoming out. It's the RFT's with the stock suspension that's causing the "bang" when you hit potholes and etc. If you swap out to shorter springs such as ZSP or most aftermarket, make sure that you swap out the bumpstops to shorter ones or you will continue to experience the same, if not more so.
05-05-2014, 10:43 AM | #5 |
Rep 60
Did a quick search. It looks like the pothole explosion is actually the bottoming out of the suspension (a few guys went to non-runflats and still had the issue).
The solution of swapping to shorter bump stops also suggests bottoming out of the shock is the issue....more travel means less bottoming. What I really want to know is the length of the koni yellow. Have they made it sufficiently shorter to reduce the chances of bottoming out? On a side note, I can't believe bmw designed a suspension with such an obvious flaw. Brutal. My E46 never bottomed out, nor should any car. |
05-05-2014, 10:26 PM | #6 | |
Rep 578
Drives: 2009 335i xDrive coupe
