E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede load values
      05-04-2014, 01:38 PM   #1
Ilma
Drives: 2008 135i
Procede load values
I am running a stacked setup backend flash with Procede and was wondering if anyone knows what load values the Procede returns to the DME.
The piggy fools the DME as to boost levels but I am curious what boost levels exactly it is sending back to the DME........stock?
If so, then would this equate back to stock load targets of 120 to 130ish?
      05-05-2014, 06:29 AM   #2
Tzu
Drives: 335i
Log DME Setpoint (or "DME Boost Target" or similar, I forget at the moment). I beleive DME target boost is reported back to the DME. In = out. I'm just starting on a new stack so hopefully I'll gain more experience with testing.
      05-05-2014, 07:29 AM   #3
Ilma
Drives: 2008 135i
Thanks!
Just looked in the channel selection menu and it looks to be "CAN DME Boost Target"
I will try it out.
Just trying to figure out what load values the DME is receiving from the procede in order to follow other table values in Tunerpro for AFR/Timing etc.
On the surface it looks like the DME is seeing stock load values in the 120 to 130 range.....but everything is so dynamic it's hard to be sure.
I'll be hitting you up to code some injectors soon Mitch
Curious to see what you are up to.
e90post
