Tstat replacement help please!!!!
05-04-2014, 01:33 PM | #1 |
Rep 1,076
Drives: 07 335i e93 6MT
So I replaced the thermostat yesterday and got coolant leak. It's coming from the bigger nipple that's held by the quick release clamp. I took that hose off and refitted it. Is it suppose to slide right in? I had the hardest time getting that thing on all the way. When I refitted it I jammed it finally on....or so I thought. Now it's leaking from the same hose again. Is there suppose to be a rubber gasket or something? Any tips on fitting that hose would be greatly appreciated.
07 BMW 335i E93 6MT (Praying neighborhood doesn't get flooded...again) 04 Infiniti G35 Coupe 6MT (Flooded) 08 Audi TT 2.0T DSG (Flooded) 03 Subaru WRX 5MT (Flooded) |
05-04-2014, 07:20 PM | #2 |
Rep 1,076
Bump. Can't get that hose secure
05-04-2014, 07:23 PM | #3 |
Rep 3,189
no gasket, Should go on easy if you pull the metal clip off, slide it on then clip the metal clip back on.
I used a small amount of grease to slide it on. |
05-05-2014, 09:19 AM | #5 | |
Rep 1,076
