Help? Input Shaft Damaged...
05-04-2014, 09:29 AM | #1 |
Rep 1,071
long story short, we didnt have the pilot bearing removal tool to remove the DAMN pilot bearing.
when we pulled the trans, the bearing was ceased in the input shaft. we tried: -pullers -heat -chisels -welding a slidehammer to it -diamond cutting wheels with a dremel -map gas -airhammer end of story, nothing worked since they are made out of stupid HARDENED STEEL, but a stone grinder in a drill, problem is, i cant tell if the the walls out of the old pilot bearing are completely gone already and we cant get a clear shave around the hump where the new pilot bearing is suppose to stop once installed. i tried inserting the new pilot bearing in, it starts to go in, and im sure it will go in with a little tap, but i know i did not make a perfect hole while shaving the old pilot bearing walls off the input shaft my question are, where the f*** can I find just a new input shaft to replace it if it comes down to it, or if i install/press the new pilot bearing in, how bad could it be if the pilot bearing is not 100% centered in the input shaft? i mean there is a little play when you install the pilot bearing in the snout at the flywheel so im assuming there is a little room for the shaft to play.
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
05-04-2014, 10:26 AM | #2 |
Rep 725
so many horror stories on the pilot bearing ,this is why i dint replace it when doing the clutch . my guess is you will have some shutter in engagement and possible vibration
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
05-04-2014, 11:57 AM | #3 |
Rep 538
Input shaft's are not available seperately. If you fuck it up, you get to buy a whole new trans. I hope it's not too late.
Have an experienced mechanic take a look at it, get a second opinion. |
05-04-2014, 12:18 PM | #4 |
Rep 1,071
well this is apparently a big issues since there is a company out there that actually makes a sleeve to repair it!
http://www.rockauto.com/catalog/more...633&cc=1433813
05-04-2014, 12:20 PM | #5 |
Rep 1,071
05-04-2014, 12:30 PM | #6 | |
Rep 719
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
05-04-2014, 01:08 PM | #7 | |
Rep 1,071
im gonna smooth in the back of the shaft to get the "hump" more defined and press in the pilot bearing with some loctite!
05-04-2014, 01:37 PM | #8 |
Rep 719
-Let us know how it turns out...
