Clunk while shifting gears
05-03-2014, 09:34 AM | #1 |
Rep 2,558
Hey all,
Ever since having a Quaife LSD installed a couple years back, I've been having a clunk while shifting gears. Typical scenario: From dead stop, put shifter into 1st and set off. Then, when time to shift into 2nd, I move the completely depress the clutch, move shifter out of 1st, into neutral, and as soon as the shifter moves into the 2nd gear gate, soft clunk, then I continue pushing into 2nd and engage. Same exact thing going into 3rd. 4-6 are fine, though. Now, if i'm coasting at say 30mph with the clutch all the way in, and I move the shifter back and forth from 2-3 without letting the clutch out at all, it clunks every single time right at the entry of the respective gate. Somehow if I do the same thing from 1-2, the clunking only happens the first time and no clunking subsequently. Also of note, the clunking causes some resistance while shifting fast, so either I really have to force the shifter into each gear to compensate, or shift more slowly. The only other drivetrain modification I have is the modified CDV. Power wise running e30 PTF COBB with cPE DCI and AMS FMIC. Can anyone diagnose the problem? Appreciate the help!
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-03-2014, 09:54 AM | #2 |
Rep 2,558
Just found this thread by dzenno... Didn't find it while searching because I didn't think to search "thud" instead of "clunk" haha...
http://www.e90post.com/forums/showthread.php?t=409095 Possibilities include: Misalignment of LSD during install Backlash not set properly Normal / non-issue (although I'm skeptical, as some report no thud/clunk with their LSDs) I had my LSD installed at VAC (the standard in these settings) so I'm sure it was installed correctly and the backlash was set properly... But maybe I should call them up for a discussion... Any other ideas welcome |
05-03-2014, 11:21 AM | #3 |
Rep 719
Pinion angle or backlash...
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
