Hard Drive Failure
11-27-2007, 06:13 PM | #1 |
Rep 9,218
Hard Drive Failure
I had a bit of a disaster last night.
I was playing Crysis (very good game) and after I switched it off, the drive on which it was installed (which also houses my documents) wasn't visible in explorer. I rebooted and got s.m.a.r.t. messages indicating the drive was failing, but couldn't access it to retrieve data. It was clicking and buzzing like crazy by now and it's obviously suffered some sort of mechanical failure. My back up was a bit old (August) so I stood to lose quite a few photos etc.. Spent the last 24 hours trying to sort it using 4 or 5 different applications. Eventually I used 'getdataback' and this evening managed to clone the entire disk. Very stressful. People tell you to back up, but it takes something like this to realise that hard disks can let you down without warning. |
11-27-2007, 07:27 PM | #2 |
Rep 1,252
Tell me about it.
I had this same problem. Unfortunately I hadn't backed up at all so lost everything. It taught me a lesson though as I now have a secondary HDD than backs everything up. |
11-27-2007, 07:40 PM | #3 |
Rep 3,445
Drives: G22 M440D
True, I deal with a lot of people whose data is much more valuable than the hardware. Managed to persuade most of them to spread the risk.
I have a couple of main PCs I use, each with a set of mirrored RAID drives and external drives / network backup and large capacity Memory Sticks. Belts ... Braces ... string ... double-sided sticky backed plastic. D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
11-28-2007, 03:54 AM | #4 |
Rep 468
Sadly, no matter how much you bang on about it, it takes a painful lesson like this for people to listen. Glad to hear that you managed to get your data back NFS.
At work I decided to take another approach, I got sick of banging on about it and helping managers nears tears (and rightly scared for their jobs) when they had lost vital data from their laptops. Now, we automatically backup data from laptops with a special agent, works a treat and the look of relief of people's faces when someone says "don't worry about it, we have all your data" is worth it alone |
11-28-2007, 04:16 AM | #5 |
Rep 5,080
Drives: 530d
A neat little (free) solution that I came across after something similar is SyncBack http://www.2brightsparks.com/downloads.html#freeware
The free version doesn't do more than copy files (no compression and no copying of open files), but can be set to run in the background basically synchronise a chosen folder to another. A bit basic, but as a first line of defence not too bad.
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i Now: 530d |
11-28-2007, 06:05 AM | #6 | ||
Rep 9,218
http://www.runtime.org/gdb.htm I tried a few other utilities and none of them could read from the file at all. This one seemed unsuccessful at first initally as well, but I ended up connecting the drive with the side of the case open and the drive lying on the floor. I then shook it from left to right for a bit whilst it was trying to seek and was rewarded with some clunking and spinning noises. Eventually it seemed to burst back into life and ran on all evening laid upside down on the floor. Quote:
I'm going to try to set them up in a raid format. Never used raid before, but I like the idea of having identical data on both in case this happens again. |
11-28-2007, 07:42 AM | #7 |
Rep 1,281
Drives: E93 M3
I've got RAID in my pc at home, with another backup going to a network disk.
I got 2 500 gb disks from different manufacturers. If there's a dodgy batch of disks then i won't have 2 dodgy ones.
E93 M3 | Azurite Black | Extended Bamboo Leather | Piano Black Trim | 19" 220M Wheels | Shadowline Trim | Edition Grills M DCT | HDD iDrive | EDC | Bluetooth | Front & Rear PDC | Heated Seats | DAB Radio | Hi-Fi Speakers | USB Audio | SmartTOP |
11-28-2007, 09:00 AM | #8 |
Rep 468
There is in fact a couple of free Microsoft tools you can use to backup to an external drive if you want.
One is the backup tool, which I personally don't like much, but will do the job. The second one is something called Synctoy, a free download from the MS site. You can use it to sync any folder with another. So, I sync my c:\documents and settngs folder (where all my files, music, piccys are kept including iTunes) with a folder on my external drive. Nice and simple to use. The nice thing is that the sync folder is just a folder, so its easy to browse to pickup one file if you delete it. Of course, nothing beats time machine if you have a Mac |
11-28-2007, 02:12 PM | #9 | |
Rep 896
How particular do you have to be about matching the drive makes/types? For instance, I have a 250Gb Baracuda and a 500Gb Baracuda (currently used in an external case for backup). If I got another 500Gb Spinpoint, could I RAID it with the 500Gb Baracuda successfully?
Phil
11-28-2007, 02:33 PM | #10 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
Viv |
11-28-2007, 02:43 PM | #11 |
Rep 5,080
Drives: 530d
I've got four of the little blighters and a pair of Hitachi's in my system
11-28-2007, 03:53 PM | #12 |
Rep 859
Drives: E92 320i M Sport
Sounds like a lucky escape NFS - well done!
I had a similar problem and now back up onto a SeaGate external HDD. Hope it's all sorted soon. |
11-29-2007, 05:35 AM | #13 | |
Rep 9,218
So I am now a hero for retrieving the info from the dead drive. |
