COLD AIR INTAKES - more hype than reality?
05-02-2014, 08:47 PM | #1 |
Libertarian
132
Rep 1,577
Ok, So I'm a budget-minded tinkerer. I'm slowly but surely adding minor mods to squeeze out more horsepower/torque on a shoestring.
I started looking at Cold Air Intakes (CAI), and first I'm noticing a big price range ($200-800). Really, how much different in performance could they really be? The other question is, some of them tout an increase of as much as 25+ hp. I find this unlikely, since these are turbo engines, the turbo is designed to PULL the cold air in... but what do I know, I'm a noobie at this crap. One of the lower priced brands claim a lesser and more reasonable 10+ hp gain. So realistically, what can I expect to gain out of say a double cone?
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
05-02-2014, 08:56 PM | #2 |
Rep 4,392
HP rating is at crank, not the wheels, so if you say 10+ is reasonable then technically your only putting down to the wheels 6 whp, which is not reasonable and you might as well keep your stock box
25 hp rating at the crank is about 12-15 whp . |
05-02-2014, 09:02 PM | #3 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
Higher flowing intakes are only going to give you any tangible results once you are tuned and start running boost of 13psi+ range. I think...
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
05-02-2014, 09:04 PM | #4 |
Libertarian
132
Rep 1,577
My thought exactly. Might make an engine sound cooler, but... meh. And I am maxing out at about 14psi boost, with a stock engine/Vishnu Procede
05-02-2014, 09:39 PM | #6 |
Out Boosting...
242
Rep 3,987
Yep… Def just get the 95 dollar dual cones!
Alpine White M-Sport F30
05-02-2014, 09:50 PM | #7 |
Rep 604
Drives: 2009 328i xDrive
Buy one used off the forum. I see them for sale all the time for good prices.
05-02-2014, 10:05 PM | #8 |
Rep 63
A cold air intake is supposed to help in 2 ways:
1) Increase volumetric efficiency by reducing restrictive air boxes/filters/etc 2) Increase horse power by feeding the engine cold air from outside the car instead of hot air from within the engine compartment. Colder air is denser and therefore contains more oxygen then hot air. With a forced induction motor, a CAI will have less of an impact on (1) above. As for (2), the basic guideline is you gain 1/10th of 1 horsepower for every 10 degree reduction in temperature. So if the CAI can get air that is 100 degrees colder, then you'd gain 10 horse power. YMMV. Good luck. |
05-02-2014, 10:09 PM | #9 | |
Libertarian
132
Rep 1,577
05-02-2014, 10:22 PM | #10 |
Black on Black on Black.
38
Rep 532
The stock airbox is too restrictive. You'll be fine with a set of cone filters.
That is all, very well documented.
LEMANS BLUE M-TECH E92->PROCEDE REV3::BIEHNTUNE FLASH::ETS 7" FMIC::RACELAND DPS::OS GIKEN 1.5 WAY::DEFIV DIFF LOCKDOWN::DEFIV OCC::DEFIV INTAKE::RB PCV |
05-03-2014, 12:16 AM | #11 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Cars have run in to the high 11's on the stock intake. You need to be making a lot of power before they are a bottle neck.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
05-03-2014, 12:31 AM | #12 |
38
Rep 532
Disagree. :]
05-03-2014, 12:58 AM | #14 |
Rep 817
I wish I knew for sure what the absolute optimal configuration was....here's a little info from Dinan; please realize i am in no way endorsing or verifying any of these claims:
"As boost is increased through the use of performance software, the single factory intake becomes restrictive and the engine is lacking the air it needs to make maximum power. Our cold air intake force feeds the 3 liter turbocharged inline 6 with greater volumes of cool, oxygen rich air for substantial power gains by utilizing our secondary carbon fiber intake. The system is so effective that the carbon fiber inlet air temperature is a full 40 degrees Fahrenheit cooler than the incoming air from the stock inlet. Due to the increased airflow from our intake, the power-curve is extended into the higher RPM’s for a noticeable change. The system is a direct replacement for the factory air box lid, employing a hand-crafted carbon fiber unit that also includes a secondary carbon fiber intake tube that captures cool air from the lower grill and includes the shielding for the conical filter to insulate it from power robbing engine compartment heat. Horsepower is increased by +14 Hp @ 6000 rpm and Torque is increased by +16ft-lbs @ 3400 rpm with Dinan® Stage 3 Software, DINAN® Intercooler and Free Flow Exhaust. Stage 2 software, Free Flow Exhaust produces 12 Hp and 13 ft-lb torque Stage 1 software, Free Flow Exhaust produces 9 Hp and 10 ft-lb torque Completely Stock car produces 5 Hp and 6 ft-lb torque Dinan Performance Software is highly recommended." To me it makes since though that this would be the best way to do it.... In fact, I'm working on a ghetto version of this concept now with a 2.5" tube (see Mr5 intake).....I'll let u guys know how it turns out. Or you can purchase a new Dinan intake for the bargain basement price of $1300...... Last edited by nikitino25; 05-03-2014 at 01:37 AM.. |
05-03-2014, 01:47 AM | #16 |
Rep 817
I wouldn't say the "hot air myth" as you call it has been proven one way or another.....DCI's are probably almost as good as a full cold air intake in most situations but I would think at low-medium speeds and for sure sitting still your ait's would be higher with DCI's. Does this matter? I couldn't really tell you...I do like the fact that the dinan method has two separate intakes though....
05-03-2014, 01:54 AM | #17 |
Rep 817
And why wouldn't a Dinan type intake flow more air than DCI's? The DCI's still use the factory intake spot and goes through the same duct whereas the Dinan uses this route and additionally has another intake near the bumper.....why wouldn't the two intake routes flow more than just the one? What am I missing here?
05-03-2014, 03:42 AM | #18 |
Rep 3,189
DCI's only have the air filters themselves to restrict any air flow.
Where as Dinan has a housing and a tube in the bumper increasing the length and restriction |
05-03-2014, 04:11 AM | #19 |
Rep 378
If hot air was such a myth then BMW and many other manufacturers would not bother to make their FACTORY intakes already COLD AIR INTAKES.
That is all. Case closed. |
05-03-2014, 05:22 AM | #20 |
38
Rep 634
The factory airbox can become a fairly large restriction on a tuned car. The bigger the restriction on the cold side of the turbo the harder it will have to work to draw in the air. The cooler the intake air the better(obviously) however there comes a point where you just have to let the intercooler do it's job and feed the turbos some air.
05-03-2014, 08:16 AM | #21 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
^^I'm thinking this guy knows what he's talking about.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
