E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > removing bms meth kit
      05-01-2014, 06:52 PM   #1
leonrojobmw
Drives: 335i
Will be taking it off to sell. Can I plug the charge pipe where the meth hose connects into or something else needed? Also, it appears the WW tank was modified to ask as meth reservoir, so I need to a buy a new tank or is a matter of disconnecting lines?
      05-05-2014, 02:54 PM   #2
leonrojobmw
Drives: 335i
bump
      05-05-2014, 06:22 PM   #3
oshusttoley
Drives: 2008 335i sedan
Just disconnect lines. There should be a plug / screw that replaces the meth nozzle on charge pipe
// JB4 ISO // Running Meth // Full FBO // E85 user //
      05-05-2014, 06:23 PM   #4
oshusttoley
Ww kit tapped into the windshield washer line the comes from the bottom of the tank, not the tank itself. Just make sure you tank doesn't leak since meth in that plastic is very dangerous and not good.
      05-05-2014, 09:39 PM   #5
leonrojobmw
Drives: 335i
Thanks, so I don't need to buy a new line, the area it wastapped can be repaired?
      05-05-2014, 10:06 PM   #6
oshusttoley
Yeah, it should be tapped with a Y. Just plug the side that was connected to the pump from the windshield washer line. Should be back passenger corner on top per instructions of BMS ww kit install
e90post
