E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB4 First Impressions
      04-30-2014, 05:06 PM   #1
vr4spd
Drives: E93 335is Sapphire Black
So after spending the whole weekend trying to install the pinout JB4 I just decided to put my car back to stock and overnight the PnP harness from Terry ( should have done this in the first place…so much cleaner)
Got everything connect yesterday afternoon, setup the steering wheel controls, routed the USB Shout out to "Damacpro91" on the N54 forums for making an OSX port of the JB4 software. Fkn awesome.
Anyways threw it on map 5 headed out to the freeway to do some pulls. First pull fine, second SES light limp mode. Didn't have my laptop with me and honestly didn't feel like reading the morse codes. pulled over cleared out codes only to experience same thing. rough idle. Decided to give it a rest for the night.
Scanned codes this morning got the misfire in Cyc 2. Swapped the coils over with number 1 cyc to determine if it was plug or CP. Codes are gone? Cars running like a champ. Just got back from dumping 70 bucks worth of gas on map 5. I have never purchased any mods for any car at any price that have been so enjoyable.
Some have reported that it pulls like a freight train on map 5, honestly its way faster than stock but I don't feel that. I had a 550 Awhp 3000gt vr4 that pulled like a freight train.
Did some logs but didn't realize they don't autosave. Anyways peak boost was about 12psi. Car is 100 percent stock minus the Jb4. Is this about what I should be seeing?
Also how long does it take to fully auto tune? 3 days?
For those with the AT I was kind of curious if you are flooring it from a dead stop in DS1 and getting wheelspin? I'm not launched at 2300 and got just enough, actually was surprised how smooth and refined it launches felt perfect. unlike my 06 vette I had that felt like I was letting go of a bottle rocket and had no clue where it was going to go.
What map do you guys use to cruise on for best fuel econ etc?
lastly how long should I wait to try some e-85?
      04-30-2014, 05:44 PM   #2
idrift4wd
Drives: Three Hundred and Thirty Five
2007 BMW  [7.00]
well map 5 takes 3 full 3rd gear pulls to "adapt"
Just stay off boost for best mpg
try e85 when your car is running 100%. I would try to use another map like map 1 to see if you are hitting target boost. If you're not then there is something wrong. 12 psi on map 5 is kind of low, so i would check for any boost leaks, maybe update jb4 firmware
12.0 @ 117
      04-30-2014, 06:23 PM   #3
SoCalHarley
Drives: 2007 335i e90
12 PSI on Map 5 with 91 Octane is what I was seeing, Map 1 would boost to 13. Map 5 with 25% e85... now that is a different story. 15-17 PSI and at that boost you will get the freight train feeling. Try some e85 you will he amazed.
2007 335i e90 Auto FBO
JB4 G5, xHP Stage 3 TCU, Wagner EVO 1 FMIC, VRSF DP's, Corsa mufflers w/x-pipe, Mr.5 intake, 25 row oil cooler, ST coilovers, Hotchkis swaybars, rear subframe inserts, Dynavin N7, 3M brushed black interior trim , Apex PS-7 wheels, Continental 235/35/19 & 275/30/19
      04-30-2014, 06:31 PM   #4
vr4spd
I did forget to mention we only have 91 here
      04-30-2014, 06:32 PM   #5
FrankyGTR
FrankyGTR's Avatar
18
Drives: N54 335i 6MT-R32GTR
i was a little disappointed with the car in stock form,bought it last week,but after the flash "procederev3"on 94oct its whole other animal,now i just put 50/50 and i cant wait to try it but its been raining non stop.
2008 335i coupe 6MT BOOST FIEND
      04-30-2014, 06:44 PM   #6
iturbo_bmw
iturbo_bmw's Avatar
Drives: 335i, 530i
if you're stock..well since u have 91 too.. i would just run map 1 for more consistency and safety. map 5 auto tuning is cool wen u mix some e85 or race gas otherwise i used map 1. u don't really have to wait to try some e85 (start at 25%, log, and increase by 5-10%) but if u got misfires on 91 u might just want to replace all ur spark plugs just to be on the safe side and not have that issue come up later as u mod more or run higher octane/map
      05-01-2014, 01:23 PM   #7
kseyfi86
kseyfi86's Avatar
Drives: 2007 e92 335i
Map 5 is garbage on 91. It always ends up autotuning to around 12psi no matter how long you give it. Stick with map 1 and it will be a good yet conservative, consistent amount of power.
Everyone is right, map 5 with say, four gallons of E85, will smash almost any car you race. I started with 5.5 gallons my first try and I hit the speed limiter at 155 HARD (Mexico of course). Haven't lost a race yet, made the new mustang GT look like it was in reverse on the highway. I guarantee you will have a new found respect for your car.
      05-01-2014, 01:59 PM   #8
suprchrgd
Drives: 335i
i have a buddy running 8gal of e85 on with the jb4 and dci only. pulls hard on map 5 for with this setup...
      05-01-2014, 02:13 PM   #9
kseyfi86
kseyfi86's Avatar
8 gallons?? Any related problems since? I'll consider bumping up the amount in mine if it works well with his.
BMS
451whp/489wtq @ EAS
      05-01-2014, 03:44 PM   #10
suprchrgd
Drives: 335i
i wouldn't recommend 8 gal, but he's had good luck with it.on map 5 with 5 gal in the tank. you will be happy. i feel you really need an inline pump at 8 gal of e85 in the tank
2008 335i MHD e40 Flash,VRSF FBO,255 Walbro,Alpina Flash
11.993@119mph
      05-01-2014, 08:09 PM   #11
msp116
msp116's Avatar
9
Drives: BMW 335XI
JB4
Well finally got around to upgrading to the JB4...took me a few days to decipher the new pinout, but finally got it up and running. Put new plugs and coils in also. Got a chance to take it out on the toll road and holy shit....pulls like a freight train is a good way to describe it...was scarry at first, but I had a shit eating grin the whole time... log says I hit 16.5 PSI in 2nd gear at 4700 RPM on map 5. This on 93 oct with DP's BMS CAI and AE exhaust..cant wait to throw some VP gas in it and try again....
      05-01-2014, 08:28 PM   #12
suprchrgd
Drives: 335i
      05-01-2014, 10:42 PM   #13
vr4spd
Spot on with the shit eating grin. I have owned a ton of performance cars in the past two years. My most recent was an 06' M5, before that a 11 e92 ZCP m3 and I can honestly say my 335 "feels" far faster, however I had an RPI exhaust on the M5 and it was intoxicating. The M3 was bone stock but 335 feels no where near as confident in the turns. Anyways I told Terry to keep my core charge for my pinout harness and send me some new plugs and DCI haha. I'm replacing the coils and plugs before I put any E-85 in it.
Can any one confirm Autohauz is the cheapest for coils @ 40 a piece?
I do love that the 335 is somewhat of a sleeper, there is a good looking chick that lives down the road that has black vert. I thought about chasing her down and asking her .." If she even JB'4's?" but Im all muscled up with tatts and she prob would bust out some mace and a rape whistle.
      05-02-2014, 06:07 AM   #14
suprchrgd
Drives: 335i
i bought my coils from getbmwparts.com
11.993@119mph
      05-02-2014, 07:18 AM   #15
msp116
msp116's Avatar
9
Drives: BMW 335XI
Plugs and coils
ECS Tuning plugs and coils $329 not bad at all.....local BMW quoted me $950 installed It was really hard not to laugh.....
http://www.ecstuning.com/BMW-E90-335...cal/ES2581741/
      05-08-2014, 11:53 AM   #16
vr4spd
Ended up getting plugs from BMS and coils from autohauz. On a side note been running around on map 1. Been getting two missfire codes as well as 3100 and 30ff anybody experience these together?
      05-09-2014, 07:14 AM   #17
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
Coils and plugs should really be mandatory when installing jb4
      05-09-2014, 07:49 AM   #18
Eat.Sleep.Race
Out Boosting...
Drives: F30 335i M-Sport
cant wait to try 30-40 percent e85 and see how this car pulls!
Alpine White M-Sport F30
      05-09-2014, 08:01 AM   #19
ThaiRacer
Drives: 07 335i
I'm still trying to enjoy my jb4 my 2step hasn't worked since I bought it
      05-11-2014, 12:53 AM   #20
vr4spd
Installed my DCI, new coils and plugs car feels amazing. I want to mix some E-85 tomorrow and do some logs however I need to get a USB extension cable only place I could find one locally was Best buy 30.00 dollars lmao for a USB cable.
e90post
