Is 2 second cold crank considering a sign for failing HPFP?
04-30-2014, 10:55 AM | #1 |
Rep 3,251
Been noticing the car took a little longer to crank in the morning on some days. Before it would fire up within a second, but now on a few occasion it take 2-4 turns (about 2 second) before firing up, and doesn't seem to be directly related to ambient temperature either. Idling is still smooth, and the car pulls like a train like it always been in the last 5 years.
The car is still on original pump (car was built in Nov. 08, with 32k miles), the dealer wanted to do the pump and injector recall a few years ago, but I told them to hold off as I never had any problem with it. The car only have a JB4 and pump gas backend flash on it, just had the intake valves walnut blasted two weeks too. Not sure if it is anything to worry about.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization Last edited by Cloud9blue; 04-30-2014 at 11:38 AM.. Reason: added mileage |
04-30-2014, 10:56 AM | #2 | |
Rep 3,625
04-30-2014, 11:04 AM | #4 |
Rep 2,114
Could also be a weak battery. Check your voltage. Every time my 328 started having long crank issues, it ended up being the battery.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
04-30-2014, 11:08 AM | #5 | |
Rep 3,251
From what I read, most dealers are hesitant to do anything about it unless the ECU starts to throwing out codes.
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
04-30-2014, 11:13 AM | #6 | |
Rep 3,251
There was a slight hesitance in cold crank before the battery replacement, but the problem seems to gotten worse in the last 2 weeks. Will check the voltage tonight just to be safe.
05-12-2014, 01:32 PM | #7 |
Rep 3,251
Well, the crank seems to went away completely after I burn through a tank of gas and fill up the newest one with 30/70 e85/93 mix. I did put techron fuel clearner in the previous tank, maybe that was causing the problem...
05-12-2014, 02:04 PM | #8 |
Rep 6,478
The E88 has been taking its sweet time starting recently, it’s intermittent and only on a cold motor. Takes a full second or two to turn over, it cranks right away. The HPFP has about 2-3K miles on it, so I really, really hope/doubt that is the issue.
I’m still on the stock battery, so perhaps that’s it? But I’ve never gotten a low battery warning before, seems odd it would happen like that. If it’s the fuel pump, I’m gunna be pissed. Spent a month, about $2K, and 4 tow truck calls trying to get that nonsense sorted out.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
05-12-2014, 02:43 PM | #9 |
Rep 780
possible the mix of the gas? i was low on gas (less than a quarter tank on an e30 mix) and got this lame snow storm yesterday and car took a little longer to crank filled it up and this morning (more snow and cold temp same as yesterday) car fired right up
